26650 batteries
Our 26650 batteries is updated.
The detail information as follows
NominalCapacity 26650 3500 MAH
Nominal Voltage 3.7 V
Max Charge Voltage 4.20 V
Discharge Cut-off Voltage 2.75V
Max. Charge CurrentCharacteristic 1C5A
Standard Discharge Current 0.5C5A
Max. Diameter 26.30 mm
Max. Height 64.95mm
Weight (Approx.) 87g
Max, at 1000Hz.) Cell Impedance:≤80mΩ
Charge Method(CC/CV) Standard/0.2C5A×7.5hrs Quick/1 C5A×2.5hrs Quick/1 C5A×2.5hrs.
Operating Temperature
Charge/0℃~45℃ Discharge/-20℃~60℃ Storage/-10℃~60℃
Without special instructions, the following tests should be done under the condition of : temperature(20℃±5℃), atmospheric pressure (86KPa~106 Kpa), relative humidity (45%~75%), discharge to 2.75 V at a constant current of 0.5C ,and the tests should be done within two weeks after receiving the products.
The batteries had been passed the test,
For this model ,we aslo have as below NominalCapacity batteries in hand now
NominalCapacity 26650 : 4200 MAH
NominalCapacity 26650 : 5000 MAH
NominalCapacity 26650 : 3500 MAH
NominalCapacity 26650 : 3000 MAH
NominalCapacity 26650 : 2500 MAH
Lazy posts will NOT get you sales. :expressionless:
+1 :expressionless:
wat
High drain 26650 @5000mAh and send 8 samples to member HJK for testing
High drain 26350 @2500mAh and also 8 send samples to member HJK for testing
Let us know when you have them.
I just updated ,Thanks!
My mom always told me:
"Now, now. Too many lazy posts and you'll turn into a raccoon."
She was right!
Please include price list. Shipping info would also be interesting.
So, are they protected or not? Flat top or button?
Send some to HKJ for testing
Yes,they are protected model,we have flat top and button in hand
I will send
Susan
Nah, don’t bother with HKJ, he is very good in testing batteries, chargers and drivers but he has a backlog of stuff to test, will probably need 2-3 months to test them and I would like to get 26650 cells much faster, I ordered Keeppower (4200mAh ones) from Gearbest but had to switch them for other things because they can not ship them to me :frowning:
For this model ,we have as below NominalCapacity batteries in hand now
Thank you!
yes,we have test report .
Hi Susan, a discharge rate of 0.5C for a 3500 mAh cell is 1750mA. For MANY members here and in other flashlight forums, high performance of cells at discharge rates of 2C and greater are required. Capacities at at least 1C discharge rate would provide more useful information. Links to each cell would also be useful.
I dunno, you seem remarkably human to me, perhaps you wish to turn into a raccoon?
I'm not a raccoon yet?
More lazy posts it is! :evil:
This line of logic suggests susan is already a raccoon :open_mouth:
I’m guessing Panda due to geological differences 0:)
