2x26650 Recommendations?
Hi All,
Just curious if there are any current/recent 2x26650 offerings out there that you would recommend? I have a Convoy L6 with an XHP70 that is great. Love the mix of throw and flood.
However, I would be interested to know if there is something out there in a slightly smaller/shorter form factor, with the same or higher output (XHP70.2 maybe?).
I’d also prefer a side switch only, if possible.
Thanks in advance!
It’s not 2x26650, but I think the BLF Q8 has similar output and throw in a shorter form factor. The Sofirn SP36 might also come close in output and is even more compact.
Again, not 2*26650, but if throw and flood of what you want than the best emitter is the SBT90.2
Both the Acebeam K30GT and K65GT are much shorter with side switches. Cost is higher though. There are less costly lights with this emitter.
Convoy L6
Sofirn SP70
L6+1 Better tints but no electronic standby
SP70+2 Bigger reflector, better UI,
something smaller with double 26650 then l6 will be hard, but what about convoy m3 ? it uses 1 26650 and has a xhp70.2 emitter ?
