3 More Mag Mods
These are 3 builds I’ve done over last last little while.
The first is a Red 4D SST90 on a custom machined heat sink, powered by 24x7135 in a master slave using high and low mode.
Second is a 3D Camo Triple XML. This was originally supposed to be powered by 3 li-ion’s in series but I had 3xAA carriers and thought I’d give that a try instead. So 9 duracell white tops in series connected to the 3 leds using the Download Multi-Lux method with 8x7135. Run time on high is pretty short. I was worried the cheap plastic carriers were going to be loaded with resistance but on high it draws a full 2.8A at the tail.
Third is a 2D Silver XP-G2 on another custom heat sink with a Rebel reflector and 6x7135. This light has 3 GP 3300 mah sub-c’s and a plastic spacer. This one has a very nice beam. Almost the perfect balance between flood and throw.
Machined by me on a giant boring mill
52mm Aspheric
Started as the DX drop in but without the original driver
xp-g2 deep in the tube
Rebel
Nice builds .
Nice work on the heat sink. That must have been fun soldering those wires to the XML.
A man of few words and many talents !
Nicely done; I really like the SST90 sink.
Nice work, I’m going to have to do a mag build, I dont fit in… :expressionless: :bigsmile:
Very nice machining again Gtamazing. The led pedestal looks like a work of art in frustration. I like em all.
The sst-90 wasn’t too bad. I did it on a cnc boring mill. The machine has 400” of travel so it was kinda like planting daises with a bulldozer but it still came out good. i saved the programing so I can always make another.
