1C3
(1C3)
5
This is not filament printing, it’s done with a different process where the shape is made from a liquid compound using a laser.
That is why it can be so accurate, I don’t think you could do small parts like these using filament, regardless of heat resistance (disclaimer: I’m not an expert on this argument).
Manufacturer specifications for this material say that it can resist heat up to 80 degrees, and the light where I used it is an LD-B4 setup with pcb sensor stepdown set at 65C, so I don’t think it should have any problems
