The T series - part of our tactical flashlight range!
Tactical flashlights are those that help with self-defense. They feature strike bezels and compared to ordinary everyday carry torches, normally have higher output brightness, strobe mode and are normally easier to quickly activate.
We will look at the T101 Pro, T102 Pro and T103 Pro USB-C charged tactical flashlights, all of which, like most of our Wuben range, are IP68 rated. We have summarised the key features of each and have included a comparison table to help you decide which of the three tactical flashlights best meets your needs!
Instant access to Free Shipping!Get 40% OFF Code:WUBENTX40
T101 Pro
Wuben T101 Pro Hunting Flashlight - 3500 Lumens
Made from 6061 aircraft-grade aluminum alloy, the T101 Pro is used for hunting and has an output of up to 4200 lumens with 500m throw. On eco mode its runtime is up to 290 hours. The emitter the T101 Pro uses is the CREE XHP 70.2 and with its optical lens, which has double side coating anti-reflective reflective properties, the T101 has a transmittance rate of up to 99%!
The T101 Pro features both a tail cap switch and a side button that has a power indicator, allowing the user to change modes and effects. Its cooling fin improves heat dissipation. It is longer than the T102 Pro and T103 Pro because rather than a cell, it uses two 18650, 2600 mAh batteries, which have electronic reverse protection.
T102 Pro
Wuben T102 Pro Tactical Flashlight - 3500lumens
Like the T101 Pro, the T102 Pro also features the CREE XHP 70.2 LED. It has a maximum output of 3500 lumens and 500m throw. Its 26650, 5000 mAh li-ion battery gives it a runtime of 240 hours and can fully charge in 4 hours. It has a single side button which also acts as a battery indicator. The button can instantly activate turbo mode and double-tapping it gives strobe and SOS modes.
Also like the T101 Pro, the T102 Pro features ultra-clear mineral glass with anti-scratch coating, fins for optimal heat dissipation and auto-adjusts its brightness to prevent the circuit from overheating. It too has an aggressive bezel for self-defense but unlike the T101 Pro, has a thread so it can also be used as a fill light!
T103
Wuben T103 Pro Tactical Flashlight - 1280lumens
The T103 Pro is available in a choice of 2 colors, both of which emit different beam colors! The black version emits white light while the champagne gold color one emits yellow light! Powered with an 18650, 2600 mAh battery, they both have a maximum output of 1280 lumens with a throw distance of 508m!
