4x18650 holder/arc welder - WARNING FIRE HAZARD
See this thing?---> http://www.fasttech.com/product/1279305
Do not buy. It could kill you.
Here, see if you can spot the potential problem:
See how high up the lower edge of that tab is? Want to guess what happens when you try to remove a flat top cell from this holder?
The lower edge of the tab slides under the heatshrink & insulator disc, bridges between the + and outer shell, and hey presto now you're arc welding!
ooh not good at all. thanks for sharing
lol.
I’m glad you didn’t sustain any damage. Are you sure it didn’t vent toxic gas? Maybe you should leave the room for a night or something.
Thanks for sharing and glad you’re okay comfychair!
Ive bought some battery holders with wires from fasttech. Not always the best quality, and often too tight fit for protected batteries.
Some models are a bit too tight for AA batteries too. So they easily get damaged on the tip or the insulation while taking them out…
Your picture shows once again why I stick to protected li-ions… You never know when something dangerous unforeseen should/could happen.
Ouch, I just want to make sure you know this, so I'll say it anyways "Don't use that battery ever again, please recycle it". ;)
Comfychair, you should post a link to this on the FastTech discussions on that same page. They’re pretty good at pulling products.
The same could have happend with a lot of protected cells which feature a flat top. The protection circuit is at the negative end of the cell.
comfy,
Sorry to see that.
Can you explained what happened? You were removing a battery from the holder, and then what?
Thanks,
Jim
so it’s a mini hid
no lumens report? :bigsmile:
Scary! O.O I’m glad you’re okay.
I agree.
Scary! glad nothing serious happened. I wish someone would make quality adjustable 18650 holders for us hobby charger users.
Can you bend the tab in a little so that it doesn’t catch on the wrapper?
That's a good idea. Fine tipped needle nose pliers should work
I should clarify my question above: I was wondering what you did when you saw this happening? I haven’t had something like this happen to myself, but I’m not quite sure what the “right” thing to do would be?
Thanks,
Jim
I would stick a piece of thin stiff plastic between the call and contact, and then remove cell.
I agree it's an easy fix, but you need to know something needs fixin' before you can figure out what to do about it. I looked the cases over before use as I do everything but this issue wasn't obvious. If all you have are button top cells it's likely you'd never have a problem like this, but as mentioned above they are quite tight and I doubt a cell that's both protected and button top would fit in there at all. The contact on the - side catches the lip of the heatshrink back there, too, so there's potential for dinging up your cells even if you don't create a DIY arc light at the + end.
Are there any sources for higher quality boxes? I mean even at triple the price it'd only be $9.
What did I do when it happened? I kept pulling on the damn thing, 'cause anything I tore up by doing that was likely to be less damage than doing nothing. Finally came out only once the heatshrink/insulator melted all the way through. It got quite hot, I don't think I got any burns but my poor hands are always so covered in burns blisters and cuts it's hard to tell :Sp
Hi,
Whoa! I’m glad (and surprised) that you didn’t burn yourself!
Was that battery holder “installed” in something, or was it just sitting one a countertop/table, so that you could have taken the whole thing outside or something?
When I was much (much) younger, I remember something like that happening, which I working at a garage (service station). One of the mechanics dropped a screwdriver across the terminals of a car battery. Screwdriver started turning glowing red… I’d never seen that before :)… In that case, I think they used a pair of pliers (insulated handles) and pulled it off.
Jim
In the timeline the first 1/2 second was the WTF? period, next 1/2 second was the decision between the labyrinthine path down the hall, downstairs, thru the garage and outside, versus throwing open the window just to my left and pushing out the screen. I'd chosen the window option but it didn't come to that. :p
It was just loose on the workbench, I'd just finished testing current draw with a bare driver & LED on a test heatsink and all the leads had been disconnected and insulated.
Ouch. That’s one nasty flaw there.
I... am going to reserve judgement on that. Total duration of the criticality event was less than 3 seconds. I checked voltage when the cell was still hot hot hot, was at 4.12v. Rechecked after it cooled down, 4.12v. And 10 hours later, 4.12v. I have a hobby charger on order, I will test it every which way possible, and anything fishy will be reason to toss it, but I'll have to see something measurably different when comparing it to the other 4 from the same batch. I am most definitely not going to just tape it up and stick it in a light.
