Hi,
I’m trying to build an LED replacement for a 628 style weaponlight, primarily as the lenses are hard to come by and are generally acrylic so can not deal with the heat from LEDs. I would also like to move to an 18650 as this is what my other flashlights use.
The tail cap thread must be the same as a surefire as it is how it attaches to the handguard. I had looked at other complete flashlights but the tail cap thread seems different on a lot of them.
I would like to keep using a larger head like the Z32 although I understand this may need to have the lamp shimmed to ensure good conductivity for heat dissipation as it’s originally designed to run an incandescent bulb with a recoil absorption system.
My current body won’t accept an 18650 which is why I am looking at changing the whole thing. So far I have only found a Z32 style head and 18650 6P body on Ali although not sure of which lamp to use. I’m used to using a Cloud Defensive Rein so would like to try and achieve a half decent output for this build.
£10.88 15%OFF | Replace surefire 6p, G2 lamp body flashlight lantern фонари compatible with 18650 battery
£29.57 12%OFF | Replacement lamp head Surefire Z32 Accessory The whole head
If anyone could advise further on the above, other options and or lamps that would be great.
Many thanks
