7135 chips and amount of lumens?
I ordered a Convoy S2+ from Simon. I wanted the 7*7135 chip option. It arrived yesterday and I like it quite a lot. Last year I ordered one of the cheap Ebay Cree 18650 tube lights for like $4 (similar to the Convoy body in overall design but probably not quite the same in overall quality). To gain some experience I changed both the star and driver. Here’s what I put in the cheap Ebay light:
CREE XM-L2 U3 1A LED on Noctigon 16mm MCPCB
QLITE REV.A 7135*8 3.04A LED DRIVER - 17mm
Now I took them out last night and did some side-by-side comparison. The Ebay model I modded is brighter but I wouldn’t say it is ‘outta the park’ brighter. I suppose this is to be expected with 5 more 7135 chips. But it does get hot on high. I’ve ordered two more drivers from ME that have only 4*7135 chips. I figured this would be more manageable.
But this brings up a question to ask. The XM-L2 U3 1A has a range of 1193-1268 lumens @ 3A 25°C. Okay I got that it will be somewhere in that range when you’re pulling 3A. Right now it has 8*7135 so it’s pulling 2.8A. Does this bring the range down and if so, how much? And the 4*7135 drivers I have coming will be 1.4A so where would the lumens be using this driver? I didn’t know if there was some calculation to figure this out (at least an approx). As a way of comparison, the Convoy S2+ with the default of 3*7135 is listed at 500 lumens using the same XML2 U2-1A LED.
Thanks guys :slight_smile:
Two places you can look for this data and I encourage everyone to do this since it’s hard to remember all the numbers for every led. The first is in the Led Flashlights - General Info thread, the first sticky is “Reference: LEDs OTHER STUFF” where a ton of info including the graphs that answer this question has been gathered. The second is where some of that info was gathered from, namely the PDF data sheets for each led. To find one of these search the web for your led, such as Nichia 219B or XP-G2 and look for a listing of the PDF. In the case of Cree LEDs I’ve gone to the Cree website and found the page with all the xlamps and bookmarked it. For the data on any single led I go straight to that page and click on the led in question and near the beginning of the documentation is a link to the “data sheet” where the graphs on current vs Vf, current vs %output, and tables with the raw lumen output of each led bin at a few fixed currents. It sounds like a lengthy process but the thread mentioned in the first method is so image heavy it is slow load. There are a number of useful links in that thread and the text for the links comes up faster than the images do so I have it bookmarked as well. I enjoy helping people but the answers to most questions have been answered and organized into some of the stickies located at the beginning of each main forum topic. It doesn’t take long to look through the lists(you can spend hours once you open a thread) and get an idea where to look for a particular answer and it’s what everyone who might answer that question has had to do.
Thank you very much, looks like I have some research to do :slight_smile:
It’s true, there’s more to being a flashaholic than just a collection. Your question involves the comparison of LEDs at different drive currents. I could just tell you a number but to me and hopefully you as well seeing it laid out is even more useful. To save you some of the trouble the link to the xlamp page is at the bottom of the Cree home page under products but Here it is for free. :wink:
With U3 bin vs U2 you gain 7% brightness
With 8 vs 7 7135 you get 14% more current.
So you get 22%(neglegting effiency loss at higher current) more output.
The human eye needs four times the brightness(400%) to percept a doubling in brightness.
Have a play here
Its slow to load and a bit of a pain to use, but it will answer your question, for Cree’s anyway.
Also the lumins stated are raw lumins out of the diode not “out the front”.
Cheers David
Edit, phat phingers
