I found a better reflector than the aluminum stock and Ledil Regina reflectors for my E1320 custom UF 2100 at FastTech and want to share my findings since a lot of members have this particular light.
I moded the light from the stock XML to XP-G2 R5 led in 2B tint while keeping the E1320 driver at 3A, it puts out as much light as the XML but in a smaller, brighter spot.
The Ledil Regina smooth reflector further concentrated the XP-G2 spot but it was a pain in the butt to center since you have to remove the plastic tabs to have the reflector sit flush with the base of the led, and usually it moves when the pill is tightened.
Found by chance this smooth aluminum reflector at FastTech that has a metal lip on the reflector hole that properly centers and focuses the XP-G2 led and gives a very good narrow spot with a nice corona.
Reflector
https://www.fasttech.com/p/1208701
Also Bought this AR coated lens, that fits perfect
https://www.fasttech.com/p/1203403
The size of the beam is exactly the same as the Fenix TK22, here are comparison beamshots
UF2100 on left P60 XML drop in on right.
UF2100 on left EagleTac D25C XML on right
UF2100 on left Fenix TK22 XML on the right
Both lights on highest setting, TK22 on top, 2100 on bottom
