Makes me want a xpg2 modded zoomie now. I only have a xml2 and a mtg2 zoomie. Have you tried doing the same mod with a different zoomie host? That one seems kinda long.
No, I haven’t. I don’t generally buy zoomies…this one was given to me so I knocked all the components off the driver, drilled a hole through it, ran a wire from led + to the spring and soldered a jumper wire from the - wire on the led to the led ground. I also put the dedomed XP-G2 on a 20mm noctigon and soldered a 16mm noctigon to the bottom of the 20mm since the pill is hollow…it all seemed to work out pretty good. I’ll get a couple of 14500 sized zoomies and try those.
NICE… I too am just getting into zoomy lights. I was never a fan before.
How did you get such a cold tint from the de-domed XP-G2 ? One of the quirks is they turn barf green/yellow when you lop off the dome. What flux/tint bin G2 did you start with?
Something I have always wondered, you think the aspheric lens shifts the tint to a more pale color?… after all thats all an LED dome is, a tiny aspheric. I am wondering if dedoming yellows and warms the tint, adding the aspheric lens cools it back down…??
