A Flashlight Modding Desk - Thoughts?
I really don’t know if this is the right section to post this in.
Anyway, I have a bunch of equipment for soldiering and it’s spread out all over the place that I have to bring together to do any actual work with. That sucks. I need to keep it all together, but space is at a premium. I had the idea to use a certain style of desk called a “secretaries” desk. It’s quite compact because the working surface folds up and also it keeps dust off of everything. So I got lucky and found one locally on Craigslist for 60 bucks and is actually really nice. So this is what I’m working with so far.
It’s actually a little too nice for soldering and electronics repair, but whatever.
I need to get some mats to protect the working surface. I’m thinking two mats. One on the back side of the hinges to keep everything from sliding around and then another mat I can use on the fold down surface. I don’t think I need an esd type mat, just a black high temp silicone should do. I want it to lay flat and be grippy on both sides. I’ll probably roll up the front mat when I’m done working so I can close the lid.
I plan to run a power strip along the top to keep it hidden and drop down the power cords to my soldering iron and hot air station. That should keep the wiring clean. I move these items forward about 10 inches when I need to do work, then move them back to close the lid.
This is all very preliminary, but I think it’s going to work out really nice once I get it built up properly.
Do you guys have any thoughts on how to make it better?
Neat Idea for limited space.
Careful, though, as I got a wall-unit that has a fold-down “desk” like that, and let’s just say they don’t hold as much weight as they might claim.
No, I didn’t sit on it or anything, but had some stuff resting on it, and one night it just came crashing down.
Nice set-up. I too am limited with space and usually have to pack up stuff after using it and put it in the back of a cupboard (else the Mrs will throw it away… )
If you partly pull out the draw maybe you can rest the shelf on that for some extra support?
I do this. I have rubber bumpers on the top of the drawer to protect the fold down top. I have no worries about the strength of the lid.
I need to figure out fume extraction. Do I want that or maybe just have a small fan. Should I add some adjustable lights or keep using a headlamp, etc…
The only pure silicone mats I can find 30” wide and 3mm thick are going to be custom length from China and cost me $70. Ouch! Silicone ain’t cheap, but it should be great for solder splatter. It will lay flat and not have an odor. I can’t find anything better.
That’s a pretty steep price for silicone mat. Maybe give something like this a try for the price?
I’m sure it can be cut to your required dimensions.
I did not see that when I looked through Home Depot. I mainly looked at shelf liners and tool box liners. It’s absorbent top doesn’t look burn proof or grippy, but I’ll check it out in person. It may not be cutable either. It looks like the edges are sewn together. Oh well, I’ll check it.
Actually, it looks like it’s not carried in any store near me.
Yeh, probably can’t cut it. And I’ve never layed eyes on it myself. Just couldn’t see payin that much for silicone.
Also, give that stuff called ’“welders blanket” a look. Not the soft fluffy stuff. I have some and it feels like rubber mat but is fireproof. Only couple mm thick. Not silicone, but darn good substitute. Check welding supply stores.
I know a kitchen product sounds silly BUT…it tolerates heat to 400 degrees F. Only .55 mm thick though. I’m just so cheap, I look for any suitable alternative…LOL… Hope you find something suitable though and I know you will :wink:
https://www.amazon.com/Extra-Large-Silicone-Pastry-Mat/dp/B07FFLYT85/ref=pd_cp_79_1?pd_rd_w=5A5Gn&pf_rd_p=ef4dc990-a9ca-4945-ae0b-f8d549198ed6&pf_rd_r=JG1BCZB3X7F2K5G743JF&pd_rd_r=6944edf3-2225-11e9-b211-f3dfa78d1ad5&pd_rd_wg=3jM2t&pd_rd_i=B07FFLYT85&psc=1&refRID=JG1BCZB3X7F2K5G743JF
I looked at a lot of the silicone pastry mats, but I don’t think that one is thick enough to lay flat. Plus I only want black. Maybe dark grey.
Rubber mat from a welding supply sounds promising.
I have been looking at THESE myself.
Those are super common. You can find them everywhere. If the size is okay for your needs, go for it. I think they make it in a few different sizes.
Louis Rossmann uses one of these.
Here is a silicone mat for $5.50 shipped from amazon
https://www.vipon.com/product/4763780-Silicone-Baking-Mat-Large-Food-Grade-Nonstick-Nonskid?ref=ss_4763780_0_image
There are tons of those as well (also available in black), but the widest is about 25”. I need 30”. :weary:
Don’t know if it will fit your needs… but maybe someone can use the idea.
I’ve set up a couple of temporary soldering stations and to protect the surface I’ll use 1/8 inch Hardboard, or 1/4 inch MDF.
It worked well for me because you can buy them in 2’x4’ sizes (not just 4’x8’ sheets) and the tables I wanted to protect were 2’x4’.
Those above are made of wood.
Now you’ve made me remember and wonder about “backer-board” it’s similar to concrete texture in feel almost, yet you can cut it with a saw (wearing mask of course) Backer board is used behind shower walls and wet areas in general.
I don’t think it would burn at 450 degrees F. though I’ve seen it in gray and green. Sheetrock guy said it wouldn’t burn.
Bears checking out though to those interested.
15X30X1/8” not cheap
“https://www.amazon.com/SILICONE-PROJECT-MAT/dp/B06X1GCF7D/ref=sr_1_89?ie=UTF8&qid=1548636334&sr=8-89&keywords=Silicone+Mat”:https://www.amazon.com/SILICONE-PROJECT-MAT/dp/B06X1GCF7D/ref=sr_1_89?ie=UTF8&qid=1548636334&sr=8-89&keywords=Silicone+Mat
3’ by 5’ by 1/4” $12.47
Quote from the WEB
Does Hardibacker burn?
Fire Ratings. … It can be used as part of a hour-long fire wall, which is a wall that can resist a fire for up to an hour when properly constructed. Hardiebacker board is generally noncombustible, and the heat produced from the fireplace will not damage it.
