A little help needed please!!
Hey all!
Allow me to explain, I have an ‘Ultrafire’ C8, typical 5 mode one, quite bright, it packs an XML-T6, run by an EAST 092 driver. Last night, I fancied a look at the emitter and driver, I unscrewed the bezel, unscrewed the pill, and removed the small black retaining disc. Found a nice (possibly genuine) Cree XML-T6, 16mm white circular one.
Replaced the disc, turned the pill over, the driver ‘was’ held in place by a posh screw-in retaining ring, so off this came too.
Nice driver to behold, it came away freely, but to minimise space, the factory based assembler had turned the driver round n around, in turn twisting the wires together.
Upon unravelling them, the red wire came away from the driver, it hadn’t been soldered in adequately. And the connection is too small for my clumsy soldering techniques, I saw this as an opportunity to replace the EAST with a single mode nanjg 105c.
It all lights up, and the nanjg (how DO you pronounce it? :stuck_out_tongue: ) does fire it up much brighter, but here’s the rub……
The emitter, for some inexplicable reason, is now offcentre, giving the hotspot an incan type hotspot, not the perfectly round bright one it used to have!!!
So, anyone out there have an ideas as to:
A) centre the hotspot
B) give an explanation as to why it’s happened
C) help me go cold turkey, buying these torches (flashlights) is detrimental to by health and general wellbeing, for my missus too, is getting ‘miffed’ to say the least.
Thanks in advance guys n gals.
Rob
I did yes
Are you locking the reflector down onto that ring? Some will fit so tightly it'll snap. It might be easier to attach it to the reflector first, and then lower it over the emitter as you reassemble the head.
We always have the answer to the least important question , here
I do not own a c8, but a lot of torches have a centering ring (flimsy plastic thingy) around the emitter onto which the reflector is screwed down to keep everything center. Can it be that there was one that has fallen out at some point?
When i snapped the black retaining ring back down, it ‘appeared’ to centre the emitter, I then reassembled torch (no flimsy plastic thingy was there) and switched it on….it was very very bright, just not how it used to be….I miss my perfect hotspot!
Further question, is the East 092 better than that unpronouncable driver?
East 092, according to some minor research, appears to be direct drive, yet still 5 mode!
Is that possible?
I can see two options, although maybe a beam shot or a pic of the reflector/emitter would help.
If the LED is sitting too low in the reflector then it’ll affect the beam, in the same way messing with the focus on a Maglite does. If it is too low, then chances are it hasn’t gone back together 100% and the reflector is sitting in the wrong place, or the pill didn’t need to be screwed all the way in if it’s gone too far down.
The other option is if the LED is no longer centered, although the point above would probably still apply. But if the LED is only help in place by friction of a thermal compound, then it might have moved.
Ok, first step has been pointed out for tonight.
Total disasseble then reassemble.
Any opinions of the drivers Mr Drumstick?
Hi,
I found the issue, the plastic retaining ring had a small ball of solder under it, which didn’t allow the ring to snap down right.
I removed it, added a touch more thermal greasy stuff….and voila….job done.
Thanks to all who responded.
Rob
