A similar light to the Sabertooth V1 2200 lumen light
I am looking for a long beam like this light has but something around 4000 lumens. I love the High/Constant Turbo/Max lumens and the second being like 300-500 lumens. Then a double tap for max lumen fast strobe like the Sabertooth V1 2200 lumens is setup in that particular configuration.
So anyone know a light more powerful etc that uses a 21700 battery. Looking for longer life than 1 or 2 18650 batteries… However if you know a good light that runs on a smaller battery than the 21700 I am open to hearing about it too. Thank you everyone!
PS
Anyone know where to find colored lens that would fit the Sabertooth V1 2200 lumen 21700 battery version?
Did they actually fulfill the pledges? Could you share some of your pictures if you actually got one from the kickstarter?
I have not seen or heard anything sadly I don’t think it made it past the kickstarter. Sad it was shaping up to be a badass light.
Any 2 mode with double tap strobe light high lumen builds you would suggest? DM please
Sorry, no recommendations because I typically don’t use strobe…a suggestion, however, might be streamlights. Their 10-tap programming might give you what you’re looking for.
