The Astrolux A01 changed when they stopped using Manker drivers
The BLF Copper version afaik does use the Manker driver.
the non manker driver has next mode memory, that the Manker driver does not
as far as the tint of your A6, thats a totally different LED, and is not high CRI
and yes, the Astrolux A01 LED changed to a higher color temperature when they stopped working with Manker. The Copper BLF has the lower color temperature LED that Manker uses
this post will give you a lot more info
you wont be able to see the manker label on the LED side of the driver unless you take the light apart, but this is what it looks like from the other side, that you should be able to compare to your two lights
here is a pic showing a manker driver on a copper BLF
the two on the right have the new Astrolux A01, w non Manker driver, and uses PWM and a 5000k LED, and has NextModeMemory(NMM)
the older Manker driver is NoPWM and has a 4000k LED, an no NMM
Basically the new Astrolux A01 is not the same, and not as good.
the printed material does not always get updated when something changes, so you are more likely to get accurate info by comparing the lights in hand, than the description
Here you will find pics of the N219 A, B and C
this is what a 219b looks like in a BLF copper
this is a 219c
here an 219a on left and 219b on right
