Hi, can anyone recommend a torch/flashlight that has some throw to it, but doesn’t run on Li-ion?
I bought someone one a few years back, think it was called an X3. It had essentially a C8 reflector and a battery tube to take 3xAA in a holder (fat handle only one battery length long).
What options are there these days for non Li-ion throwers? Doesn’t need to be extreme, it will be for checking horses across a field. Compact’ish would be a benefit, but any considered.
I know Maglites would seem a good candidate, although a little chunky and heavy maybe. But in the UK they seem difficult to get these days and when you do find them they are way too expensive.
Alkalines just die very fast somewhere between 0.2A and 0.5A (~25-60lm) per cell regardless of brand, they can’t handle any kind of high load, the funny thing is that even D cells aren’t any better, so use NiMh or lithium AA primaries.
The Maglite ML25’s throw real well and are very compact for C cell lights and cost less than other Maglites.
The 3 Cell version is great for running alkalines but if you are running mostly NiMH’s, I would recommend the shorter 2C version.
In fact the 2C ML25 is about the same length as the 2 AA Mini Mag.
The ML25’s can be run on AA’s in a simple spacer sleeve or even 18650’s with an adapter.
TN4A/TK4A/SF11. Tomato-paste-can light that takes a quad of AAs. Over 1000 lemons out the pipe.
Barring Mags, Luxpro makes a 2×D light that uses a vile little XP-G3. Hateful little chip yields a urine-yellow corona, but the hotspot is quite small and it’s a rather throwy light.
Amazon.com is the one I got, the v2, but there’s a v1 that’s 2bux cheaper. Dunno what’s on a.co.uk over yonder, though.
Also takes adapters (which I bought separately) to use 3 AAs in parallel in each D-cell-sized doodad, too.
I pimped out mine by replacing the plastic front-“glass” with actual glass, and sticking diffusion film on the inside to mellow out the beam. I don’t need a thrower, so floody is fine. Lets me burn down moribund AAs to almost nothing, too.
A couple of years ago I bought a bunch of AA lights, and the best, by far was the Jetbeam sra40.
It was built like a tank, had built in charging and threw like crazy. It’s still one of the best AA lights I have
ever owned.
I don’t know if they still make it, but I see them used online.
I think there were a couple of different models over the years in regards to output.
If you get a used one make sure to get the charging cord with it. It uses a non standard type plug.
My father in law was impressed by one of my 21700 throwers and has asked for one to use on his farm for viewing out into his field, but I don’t think he would be cautious using li ion batteries. I would even provide him several lithium primaries (the energizer AA primaries) if I find the right light. Feeling like I might be better off getting him one of those medium size spotlights at Walmart to get him the throw he wants.
I like to run the 5.11 XBT A6 in my vehicles. The size of a 3D maglite so its easy to find and hard to lose plus runs off 3AA or 6AA so L91’s are the go to option. Throws like a champ, too. I tried cracking my extra one open to swap LEDs from what is probably an older XML but even with a heat gun I wasn’t able to loosen the bezel. Oh well, its discontinued anyways, although 5.11 does have a different 6xAA flashlight which I haven’t tried myself.
If I wanted a AA thrower I would probably look at the Jaxman M2 and swap that LED out for something newer and smaller (stock XML, should throw nicely with a 3535 footprint emitter). … And I now see this is also discontinued. Dang…
Oh! One other option that comes to mind, though it may not be what most people are looking for, is the Streamlight Survivor. It can be had either as NiCD rechargeable or with a 4xAA battery caddy. These put out a very concentrated, throwy beam designed to cut through smoke and are extremely durable if not a bit unconventionally shaped.
