Hi, I’m looking for a flashlight with these requirements.
Must haves
Size 3-4 inches around a single AA sized light. Traditional cylinder shape.
USB C rechargeable without having to take the battery out to charge it
Tail switch operation that starts out in low mode.
2 way belt clip
under $50
I think a i5r is the closest to my requirements other than I would have to take out the battery to charge it. Is there any other simular options I should look at? Thanks!
Any light that takes a removable 14500-sized cell will generally NOT have a charging port, because you positively know some smoothbrain will stick an alkaleak in there and try charging it.
Lights which have non-removable cells, though, you got a shot.
Oh I see, that makes sense. I don’t need a removable battery I just want to charge with USB C thru the flashlight instead of taking the battery out and charging it sepratly.
If the issue isn’t opening up the light, but instead simply not needing a separate charger, the Acebeam Pokolit has a double-length Li cell with a charging-head built-in, and can use 2 alkaleaks in a pinch.
Pop out the cell, connect the cell to the usb cable (ie, no charger needed), and then stick it back in when done.
I don’t want to have multiple cords and everything else I have is C so it would be a pain to have a single item on micro. That light otherwise would be a great choice for me. Thanks for the suggestion.
Olight I5R EOS 350
Bit more than $50 but maybe on sale for Christmas.
Customized 1420mAh lithium-ion battery that integrates a USB Type-C interface for charging
The final “I got X” posts at the end of these recommendations/requests threads are the icing on the cake for others looking for similar lights- thanks for posting the update, enjoy your new light.
Re. HS10, I’m really hoping sofirn brings releases something similar in AA/14500 format in 2023, I’m not holding my breath though.
