Ok, so all my drivers showed up in the last few days.
The ld-25 for my edc18650 build and the three 4a drivers, one for my m10, one for a give away m10, one to perk up a ke-5 (mental note, must pm adyScarborough).
Onto the edc, after a little pill fettling, I have the driver sitting snuggly. Soldered in the u2, soldered the ground path, spent ages cleaning up the solder from the threads of the pill (if anyone is thinking of building this as a first host kit, get a bigger light first to get your eye in, this damm thing is tiny!)
Got it built up, grabbed my spare cells, not one is over 3.6v…. Anyway, it should do to check it works… I can get medium, low, a flash out of strobe and SOS… I don’t want strobe or SOS, no worries, the modes are switchable, all I have to do is turn to low, wait three seconds, the light flashes, quickly turn off then on, into three mode group. Hi-mid-low. Can I get this to work? Can I hell!
Never mind, the driver I wrecked is in this group, but I’m sure I’ll figure it out…cells on charge, onto the m10.
Removed the pill, removed the nice brass driver retaining ring, this swap is going to be easy……
Hmmmm, that driver looks big, yep its 20mm, what did I not order? 20mm hoy baffles…… Quick check, there should be space for everything, just need to order said boards….and wait for the fricken post again….and not test the set up, ready for the give away……damm!
Upshot is, my new iron and solder sucker work a treat, good news, and I’m set for tomorrow night’s foray at don kidik’s. We’re hopefully adding a potentiometer to a couple of small suns to dial in the current and sort out a drop in that’s playing up.
My confidence is not high at this point.
Still, its all good fun, and a learning curve, and at least my edc is ready for a nice lanyard to be tied later in the week.
