Sorry but uh…after messing around a bit, I found that it was the flicker from the TV and the major flicker coming from the 1ms Motion Blur Reduction feature on my monitor that was causing all those problems. There is still a tiny bit of flicker but it’s barely noticable. I still definitely need more light to play with though. Currently I use 3 400-ish lm (I think so anyways) supacell bulbs, not sure of the color temperatures. After changing the exposure from auto to 0, the webcam is very dark and well under 30 fps. Shows I need more light.
Think I should get the Soraa with 800 lm each? Or should I go with the daylight 1055lm from Phillips and lose a bit of color quality? I’m not an expert with this kind of stuff so it’d be helpful if someone could give their opinions on these bulbs. I’m not after other stuff that aren’t e27 bulbs, I’m just interested in these 2 and any other ideas you may have to solve this problem, thanks.
