1. I was thinking about modding an old bike light, started making plans and then I realized that there is no enough space in light compartment for driver!!! It's a CatEye Double Shot and in factory setting it had a driver in battery compartment.
So, what would you say, which wire length would be OK (max) from driver to emitter?
2. Thought to get a few new XP-G2's and reflow them on my "old" XP-G stars but noticed a difference in voltage, old XP-G R5 is 3.0-3.6V and new XP-G2 R5 is 2.8-3.15V, should I worry, idea was to connect 2 x XP-G2 in parallel to nanjg 105c!
Its not so much the length, but the size of the wire. You need to use as big as your application will let you. The bigger the less the resistance and voltage drop. Here’s a nice calculator that might help. You can change the wire size to see the differences in voltage drop.
I’d just try upgrading the LEDs and (complete POS) optics first, plus have a fiddle with the driver in the battery pack. I managed to increase the current from 600mA to 900mA by turning a random white knob. That plus XM-Ls and good Regina reflectors made for easily twice the light output, plus a more useable beam. I did a write up on mtbr DIY forums, you should be able to dig it out. A guy named Marpilli also did what you’re suggesting and made a small driver+switch box on sit on top of his helmet - he was very happy with the mod. Or, you could put in one LED (say an XM-L) and the driver in the other side - run it at 3A (housing should be able to take it with some airflow) and you’ll have a lovely bright light.
Whatever you do though, get the housing good and hot before you try and unscrew anything, otherwise you’ll strip at least one screw.
@moderator007 - thanks for that calculator, that will definitely be handy, bookmarked it :)
@DrJones - it's a mobydrv ordered from some guy here on BLF :D
@mattthemuppet - it's a friend's light so I actually don't have it in with me yet, but I know that it's not working. I saw that upgrade by marpilli (mtbr) I also saw upgrade of triple shot version where guy replaced left and right LED with XML's and installed driver and front switch instead of middle LED (looks awkward). When I get that light I will try to make a room for driver to sit between 2 optics (didn't plan to change TIR's I don't know their exact dimensions and finding replacement reflectors, ordering and waiting them to get here all the way from China would take a looooong time, everything else is on its way).
Again, thanks guys for helping me on this :) I expect a lot of fun time with this project :D
