Accucel 6 as a power supply
I recently realized that my Accucel 6 can be used as a power supply to test my LEDs if I set it to charge LifePo4 1S at what ever amperage, sadly on: Nimh, Nicad, LiPo, and Lead acid it won't work due to the low voltage protection. Does anyone have any idea on how to disable that?
Or the other option would be reprogramming the microchip in it to allow you to set the voltage and amperage, this would prevent it from being used as a charger but if it could be done this would be amazing.
On my version, I can set the current on NiCd and NiMH mode like a constant current driver, regardless of the voltage it’s hooked up to so I can test out LED’s and such.
I’ll try LiFePO4 mode on mine soon.
I had this thought the other day, can a charger be used as a 120V led power supply
120V? I don’t think so.
Interesting! Thanks for the tip Scaru, will the charger show an error message of any kind?
I was thinking about this as well a while ago. Going to go try it out!
Just tried this. Works great!
I just tried it with an XM-L and it works! Measured a bare star no heat sink at 0.1A and the vf was 2.64 volts, this is cool! Thanks Scaru for the tip! :beer:
Edit: Forgot to add that I tried it with the Turnigy Acucell 8150 Charger, after setting for 1S the XM-L blinks for less than a second, then the charger recognizes it, I just confirm 1S and press start and it lights up at the set current.
I was thinking about trying to find a desktop type test power supply and found this thread!
I want to test a Luxeon 3up, with the emitters in series. The Luxeon emitters are spec’ed for 3V at 1000 mA (1 amp), so I’m looking for ~9V at 1000 mA.
So with my Accucel 6 work to drive the 3up if I set it to LifePO4 and 3S (just to be safe) and 1.00 amp to safely drive it?
Thanks,
Jim
I’ve had my accucell smoke leds on start up when it does a cell check
Did you have the Accucell set for LifePO4? If it was the default, I think it’d try to charge to 4.2V vs. 3.6V.
Hi,
How are you all even doing this? I have mine set to LifePO4, and it fails the check and says “CONNECTION BREAK”.
EDIT: NVM. Got it working. I think that it actually has to have an emitter attached (emitter + to red cable, emitter - to black cable), and set it to 3.3V/LiFE.
When it does the connection check, it must output some current, and checks if there is some return current. Earlier, I was trying with nothing connected, which cause the “CONNECTION BREAK” error.
That initial test causes it to blink, and then the screen changes to allow you to confirm the current and voltage/number of batteries (e.g., 3.3V/1S, etc.), and you push Start button, and then away it goes (still kind of seeing spots - didn’t realize how bright it’d be a only 0.3A).
EDIT 2: For the record, I tried this with 3up Luxeon emitters, and it worked when set to 1S. If it was set to 2S, it’d work for a few seconds, then the Accucel would stop with an error. If it was set to 3S, it would give an error and not start.
Got a question, if I measure vf at same current on all the LEDs I have, will the lowest vf measured led be the brightest or most efficient at producing light?
