Acebeam E75 Nichia 519A Dedoming Tutorial
Turned out a tad warmer and rosier than FFL351A 3700K NW CRI95.
Sriracha and Beamshots included: https://imgur.com/a/acebeam-e75-nichia-dedoming-guide-Wo6dun4
Notes:
  • used tape to remove the lens
  • no need to remove reflector - I used flat tweezers to gently twist domes off
  • beam pattern will be tighter. It’s tighter than my Wurkkos HD10 (30°), so maybe ~20°
  • rosier and warmer than my FFL351A 3700K NW CRI95
I’m delighted with the tint (skin tones look great now), but beam pattern is less useful for indoors. Overall glad I did it. My first flashlight mod!
As a fellow 519A dedomer: I recommend caution about any method that exerts much force on the dome. The dome is attached to the glass layer by vacuum, so any pulling/pushing/shearing force exerted to the dome transfers directly to the glass and phosphor. There are many reports (e.g., [1][2][3][4]) of such methods detaching the phosphor entirely from the die, or reliability issues in the long run due to initially undetectable delamination of the phosphor.
Personally I remove the dome in layers using a razor blade, and scratch off the final layer gently with a plastic toothpick (though leaving it on is fine too). This method uses very little force (due to the small cutting area of the blade) and has successfully dedomed 20+ 519A’s, none of which developed issues after months of heavy use. It is certainly less convenient than your method, but might be worth considering for someone who doesn’t want to risk an expensive light.
Ah that’s a good point.
FWIW, I also dedomed Skilhunt EC150, but added a turbo pre-heat. Warming it up made it come off with much less force, akin to prying a gummy bear.
That definitely helps! Once softened the silicone is much more likely to peel from a side/corner rather than stick entirely to the glass.
