This proprietary battery self discharged over a period of weeks while the light was stored in my campervan, letting me down when I needed it.
Acebeam replaced, so this one can be dismantled.
Acebeam claim 2 x 21700 batteries can be used instead of this, but I’d dispute that as they’re about 1cm shorter due to the protection circuits and charge port. No idea what caused the parasitic drain, but it’s been reported on Reddit so I’m not alone.
The 2 batteries are on the charger and register 3v so the protection circuits kicked in.
Not sure what batteries they use, the max amp draw would be handy to know, but I’m sure they’ll be fine in a Wurkkos or Sofirn that’s not pushing the envelope too hard.
Don’t own one of these so no skin in the game, but I’m curious, is the self-discharge due to the light or the BMS assembly making up the battery?
Given you suggest cells were at 3V, it also seems strange to me that once the shut-off is activated, the BMS prevents any charging, this would be a concern if you ran it flat in the light, no? I could perhaps understand a more sophisticated BMS which prevents charging if cells go below the “do not recharge” voltage on the datasheet.
You might find you can make up the length with one/a couple of those PCB buttons from Convoy designed for using flat-top cells in series.
Definitely battery. It dropped voltage over time while uninstalled. Also, the new one behaved fine while installed and in storage.
I reckon it’s a bit shoddy of Acebeam to say that 2x21700 will fit in place of their battery. Not easily they won’t. Had another measure and it’s about a 13mm difference. Running 2 cells at 8.4v in a powerful light isn’t ideal if there’s a big gap that needs packing.
Anyway, all done with that as I sold it, another torch like the FFL Artemis that caused me more pain than pleasure. Just happened I was taping up a few duff cells for safer recycling today and decided to break apart the P20. The cells are still on charge and seem fine so I’ll be keeping them. They’re on 4.1v each and taking a nice long time about it.
