ACEBEAM X80GT 3 – 23,000 to 30,000 Lumens in a Compact Body
Product Introduction | High-Performance Flashlight for Outdoor Activities, Caving, and Demanding Lighting Applications
Hello everyone,
Today, I would like to introduce the new ACEBEAM X80GT 3. This compact, high-performance flashlight is an interesting option for anyone who needs a tremendous amount of light in a relatively small package and values versatile features.
ACEBEAM positions the X80GT 3 as a powerful floodlight for outdoor activities, expeditions, and caving. Particularly interesting features include its multiple light sources, stepless brightness adjustment, and well-designed mounting options.
1. Compact Design with Enormous Light Output
The X80GT 3 combines a relatively compact housing with an exceptionally high maximum light output.
Depending on the version, the white-light model delivers up to 30,000 lumens, while the multi-light version provides up to 23,000 lumens.
This makes the flashlight particularly suitable for situations where large areas need to be illuminated, such as forest trails, cave exploration, or outdoor environments.
However, it is important to put the maximum Turbo output into perspective. This mode is designed to deliver exceptionally high light output for short periods. For extended use, lower brightness levels are often more practical.
2. Two Versions for Different Requirements
One of the key features of the X80GT 3 is the choice between two different lighting configurations.
White-Light Version
- 24 high-performance LEDs with a color temperature of 6,000 K
- Maximum output: 30,000 lumens
- Specified maximum beam distance: 430 meters
- Stepless brightness adjustment from 150 to 3,500 lumens
- Integrated battery pack with USB-C fast charging
This version is aimed at users who prioritize maximum white-light output and broad area illumination.
Multi-Light Version
- 18 white LEDs, available in cool white or neutral white depending on the version
- Four red LEDs with a wavelength of 660 nm
- Two UV LEDs with a wavelength of 365 nm
- Maximum main-light output: 23,000 lumens
- Stepless brightness adjustment from 100 to 3,200 lumens
- Replaceable battery compartment for four 18650 lithium-ion batteries
The multi-light version offers additional applications. Red light can be useful for certain tasks in the dark, while UV light is suitable for specific inspection and detection tasks, provided the application is appropriate.
Important: The two versions differ not only in light output but also in their power supply systems and available light sources.
3. Stepless Dimming and Regulated Light Output
An interesting feature is the stepless brightness adjustment. Instead of switching exclusively between preset brightness levels, users can adjust the light output within the available range to suit the situation.
The manufacturer also specifies flicker-free operation and an FCCM boost constant-current driver. This technology is intended to provide consistent light output.
Proper power management is particularly important during extended use. The highest brightness setting is not always the most practical choice. A lower setting can extend runtime while still providing sufficient illumination for many tasks.
4. Additional Side Light with High Color Rendering
In addition to the main light, the X80GT 3 features a separate side light with a color rendering index of CRI ≥ 95.
According to the manufacturer, the side light can be used independently or together with the main light.
High color rendering is particularly useful when colors need to appear as natural as possible. This can be beneficial when working with equipment, sorting objects, or navigating at close range.
For a versatile outdoor flashlight, this is a practical addition because not every task requires the maximum output of the main floodlight.
5. Housing, Operation, and Mounting Options
The housing is made from CNC-machined, anodized AL6061-T6 aluminum alloy. A 4 mm anti-reflective glass lens protects the optics.
The flashlight offers several handling and mounting options:
- Handheld operation
- Removable handle for an additional grip
- UNC 1/4-inch thread for mounting on a compatible tripod or accessory
A three-position magnetic-mechanical lock switch is also included. It is designed to improve handling safety and help prevent accidental activation.
The specified IP68 protection rating and one-meter drop resistance underline the flashlight’s suitability for outdoor use. However, the actual limits depend on the testing conditions and how the flashlight is used.
6. Charging and Power Supply
The power supply differs depending on the version.
The white-light version uses an integrated battery pack containing four 18650 lithium-ion cells. It supports USB-C charging at up to 60 W, with the manufacturer specifying an approximate charging time of one hour.
The multi-light version, on the other hand, features a battery compartment for four replaceable 18650 batteries. This is particularly appealing to users who carry spare batteries and want to swap them during longer trips.
It is therefore worth checking the exact version before purchasing. The specified charging time does not automatically apply to every version or every battery state.
7. Technical Specifications at a Glance
Feature
Specification
Manufacturer
ACEBEAM
Model
X80GT 3
Maximum output, white-light version
Up to 30,000 lm
Maximum output, multi-light version
Up to 23,000 lm
Maximum beam distance, white-light version
430 m
LEDs, white-light version
24 × 6,000 K
LEDs, multi-light version
18 white, 4 red, and 2 UV LEDs
Red light
660 nm
UV light
365 nm
Side light
CRI ≥ 95
Brightness adjustment
Stepless
Housing material
AL6061-T6 aluminum
Protection rating
IP68
Specified drop resistance
1 m
Body diameter
49 mm
Head diameter
65 mm
Length, white-light version
128 mm
Manufacturer-specified weight
Approx. 560 g
Charging port
USB-C, up to 60 W for the white-light version
Mounting
Removable handle and UNC 1/4-inch thread
These specifications are based on manufacturer and retailer information. Technical values may vary depending on the version.
8. Initial Assessment
On paper, the ACEBEAM X80GT 3 appears to be a versatile flashlight. The combination of high light output, stepless brightness adjustment, and an additional side light sets it apart from more basic high-output floodlights.
The white-light version is particularly appealing to users who need maximum brightness. The multi-light version offers greater flexibility thanks to its red and UV light sources and replaceable batteries.
On the other hand, the weight of approximately 560 grams and the relatively large flashlight head are factors worth considering before purchasing. Rather than being designed as a lightweight everyday carry flashlight, this model is better suited to dedicated outdoor and demanding lighting applications.
A final assessment of beam quality, heat management, actual runtime, handling, and build quality should only be made after practical testing, including measurements and comparative photographs.
Conclusion
The ACEBEAM X80GT 3 is an interesting new option for anyone looking for a powerful, compact, and versatile lighting solution.
The two different versions are particularly noteworthy: maximum white-light output on one hand, and additional red and ultraviolet light sources on the other.
The best way to determine whether the flashlight lives up to expectations in real-world use is through personal nighttime photography, runtime tests, and direct comparisons with other high-performance floodlights.
Further product information:
*Note: This article is a technical product introduction based on published manufacturer and retailer specifications.
Kind Regards
GATZETEC
flashlights for friends
Service@gatzetec.de
