Newbie here,just recently completed my first build.
Looking for good advice for my next build.
I prefer an 18650 host for the new XHP70.2 led.
I understand the higher voltage with more than one battery allows for lower current draw, lower heat, and is thus preferable.
(Is this correct?)
If so, I’ll need to find a good 2x18650 host. For some reason Mountain Electronics seems to have only 1x 18650 hosts these days.
(Any recommendations for another vendor? Preferably based in the US…)
Any advice on the preferred driver for this setup? Is it true that the Mosfet drivers are most appropriate for this?
(Any recommendations on a specific driver? If so, please indicate a good vendor)
You are sort of correct about the higher voltage making less heat, but not really. You can transmit power over wires more efficiently at higher voltage, but there is not really the same advantage when it comes to LEDs. All other things equal, you’ll be using the same power and getting the same light whether you use one or two cells. That being said, the XHP70.2 is an efficient LED so it is a good choice.
There are not as many 2 cell hosts around. Another option is using a single cell host with a boost driver. You could use a C8 host and 17mm boost driver, both from Mtnelectronics. That boost driver is a bit expensive, but it is an option. (Just remembered that the c8 reflector won’t fit the xhp70.2 without a bit of modification. The LED is too big for the center hole)
A 2 cell host with a FET driver will give you more power, but an advantage of the boost driver is the modes will have regulated brightness.
1) you mention the use of a FET driver. On the Mountain Electronics product info for the XHP70.2 LED, they say:
_“Please note that the XHP50.2 has an extremely low forward voltage. It may be damaged by use with an FET driver and high-drain 18650/26650 batteries! You may have to add resistance through thinner wires, weaker cells, etc. to use a single XHP50.2 with an FET driver!”
I’m not sure how to go about getting a “weaker cell” or thinner wires, but I suppose adding a resistor in series might accomplish the same thing…(although I doubt there would be enough room in the driver pill to accommodate that)
2)I had thought about a boost driver, but then I learned that there is a 3v option for the XHP70.2 LED now.
I suppose this would allow me to use a common inexpensive 3v driver such as …
Do you think this will work? The price is certainly right!
The xhp70.2 and xhp50.2 are different LEDs. The xhp50.2 is smaller than the xhp70.2, but still bigger than your typical 3V LED.
Using the 3V xhp50.2 with a FET driver is an easy way to get a lot of lumens. The driver you linked would work, but it is only 3A so it would not be nearly as bright. You could use a FET driver like this one.
