This build was inspired by a very kind gift from JohnnyC, of a custom programmed 1050mA AK-47 driver. I'd originally intended to use it for a 4D magmod, but after fighting with the battery straps on my current commuter light and getting snow down the back of my neck, I figured it'd be more useful in a commuting light (which I could still use as a torch/ flashlight). It would also make a handy loaner light on mtb rides as fellow riders start getting caught out by the earlier nights.
Parts: 1A USB charger, XM-L T6 3c (first go with a NW emitter!), AK-47 ever so kindly donated and programmed by JonnyC on BLF, with 2 380mA chips added for a total of ~1.8A (a good spot for a single XM-L on a single cell), Judco switch from Digikey, LC1 optic (will be used without holder) and ubiquitous Cateye spacer. NCR18650 was on order from CNCQG and checked out very well on my hobby charger (shame the same couldn't be said about the NW XM-L I ordered from them). A simple PCB from DX (not in pic) was attached to provide basic protection.
an abundance of raw materials and a perpetually messy work bench
Making the sled to hold the LED and driver
fully lapped and polished, with taps for the LED and housing/bracket screws
backplate cut out
and with USB>li-ion charger cut up and roughly in position
all the internals wired up
back end. Charger board is epoxied in place and the battery was hot glued to the sled after this pic
switch and driver. I have to say, I thoroughly hate soldering the LED- wire to those tiny tiny pads. Ended up scaffolding up the -ve legs of the 2 AMC chips to get a robust joint.
Business end. Screws are from an old microscope filter wheel a friend gave me. Spent the whole evening taking them out and now I have hundreds of them! LED base was also lapped and polished before attaching with some chomerics thermal paste.
optic being epoxied in place, with driver getting attached with JB Weld. I got it into my head that this would provide better thermal monitoring (or heatsinking of the driver), but even if that's nonsense it'll still stop it rattling around.
6in of stiff aluminium (ahem)
my continuing inability to drill holes exactly where I want them
all assembled (yay!). Switch cover was a complete *&^%$ to get on, so I had to remove the rubber boot and pull up on the switch with a pair of needle-nosed pliers while screwing the plastic ring down. Still, an old AC o-ring between the switch and housing plus some silicone under the edge of the boot should keep things sealed. The holes in the side of the head are for side visibility at road junctions.
2.3mm lexan cover, sealed w/ 5min epoxy (yes, I know I still can't get the LED/optic perfectly centered :))
back end, with charging port (cover from FrozenCPU) and little status light window. The silicone sealing the backplate was still curing - when it's cured it's transparent.
all lit up!
and, finally, the beamshots! Control, followed by 2s then 3s (auto ISO I think).
Absolutely beautiful beam pattern and tint, I'm very very glad to be converted to NW by everyone on here. Whenever the next gen XM-L comes out I'll start converting the rest of my lights (already have the LED for my other commuter light) for sure.
It got used in anger as a loaner on Tuesday night and the rider was very happy to have it. It did a surprisingly effective job of lighting up the trail (given that I'm used to using 2 lights, 1 with 2 XM-L U2 @3A, the other with the same @1.5A!) and the definition was fantastic, better than my lights. It got lots of good comments from the other riders too. Only downside is that it's a bit long (I'd worry about my knees) and there's a very high pitched whine from the driver on low and medium, although that's completely inaudible on the bike.
So thanks again to JohnnyC and to all the BLF NW nutjobs :)
