ALL SOLD
Up for sale are three TWO ONE lights.
Two of them are the Yupard lights I got a little while ago. I have spent a lot of time going through them.
These are 3x16340 lights with XM-L2 (very cool white), leds in them. The drivers are 2800mA Qlite and the program is the DrJones free to use program he just put out. The chips were burned for me, by another member here. The modes are (PWM values of 5,50,125,255). Press and hold for a second to turn on, press quickly to change modes, press and hold for a second to turn off and it has last mode memory. I went through both lights and put a copper back plate behind the original stars. I used heavier wires as well. I also braided the springs and I drilled and tapped the holes for the spring plates to accept 3mm screws. The tail caps are glued in, because there is so much play and I don't see a need to touch them now.
Beam Shots:
These are not throwers, but they have a nice beam and would be great for walking.
Next up it the TR-J10 I just finished. See the build thread here.
It is an SST-90 light. It runs on two high powered 26650 or 18650 batteries. It draws 8.6 amps on high, so you need really high drain batteries. I have modded it by placing the SST-90 on a copper star and modified the driver to get the higher amps. I used all new wire and all springs are braided to take the heat/amps. Modes are H/M/L/Strobe/SOS. I have not addressed the small spots where there is ano mising on the battery tube ends. I am leaving it as is. It does not look that bad and I don't want to get into a bunch of cosmetic work, as that will just increase the price and my time into it.
Beam Shots can be seen in the Build Thread Here.
*** Polished Yupard is SOLD.
*** The TR-J10 is SOLD.
Price of the one Yupard in Black is $44 $35 CONUS and $44 International
Price of the Trustfire TR-J10 is $47.50 CONUS ADD $10 for International.
Payment is PayPal oldlumens (insert the @ sign here) gmail.com
Post here which light you are taking, so we all know and follow that with a payment and a PM to me, with your full name and address.
Thanks
