Alternate Firmware for FET+1 (A6 driver from Banggood)?
Hi guys, I bought quite a few of the A6 drivers from Banggood. While I absolutely adore Toykeeper’s A6 firmware, when I use this driver & firmware for my triples, the heat causes the timing to get really messed up. After it heats up, all I can get is the medium and long press (no short “forward” presses), so I get stuck in the hidden modes.
Is there an alternate firmware that I can use with this driver that has no reverse (medium press)? I don’t need anything fancy, but I prefer no memory with (off-time) mode changes. It doesn’t matter to me if it starts on the lowest or highest mode first. Any guidance would be much appreciated.
If you have the ability to flash your own firmware anyways, the blf-a6 source code is available and easily modified to remove the backwards press and hidden modes, and keep the two mode groups (that you can set yourself) and the memory on/off toggle. It’s what I use in most lights
The root of the problem may be a cheap capacitor on the driver though, so you may still have a few issues when it gets really hot
