Just arrived. You and Tom were both correct. The cells are wired 2P, so I guess we have to use their battery pack or build a dummy cell, or replace the driver. Iāll see what others are
going to do, but for now Iāll try it out as is.
[/quote]
What is the reflector size? Good thrower or is it more flood?
[/quote]
Reflector is 2-1/4ā and should be a respectable thrower. Pretty deep reflector on this one.
The head seems to be glued on, so I canāt remove it to measure depth. I really like the look
and feel of this light and the easy to use side-switch. High-Low, and hold down for 3 sec for strobe.
Also, I get 3.68a on HIGH and over .9a on LOW mode.
Mine just arrived too. It's actually a decent beam, decent tint and well defined hot spot, though it has some artifact rings, probably from the protruding up centering piece. The top of the batt tube unthreads easily but couldn't budge the bezel by hand yet. I'll check it out in the office, take some measurements.
On the batteries at ~4.0V, 1115 lumens on hi, 285 on low, 132 kcd taken at 5 meters on hi. 4.5 amps on hi, 1.08 amps on low.
Driver is 28.1 mm in diam, includes the charging circuitry, and includes a driver mounted switch.
Reflector I.D is about 57 mm and head diam is 70.7 mm.
I noticed something blocking the USB connector and realized it was a metal fragment. Tried to grab it with a tweezer and it fell in to the driver cavity -- not good, so I had to open it up. The piece is shown below, size compared with an e-switch:
Full view of the driver. Plenty of room for a sandwich driver, though losing the charging:
SFT40 would be near perfect for this light. Just above the LED appears to be a contaminant, think it's a loose particle of some sorts:
Tried opening the bezel with my sticky gloves and no luck. Need to get it on the bench with the strap wrench.
Don't expect much in quality - it's not a Convoy:
crude pointy threads
black anodizing rubbed off at a few edges, almost as if the flashlight was used. There was no packing bags and the lanyard was already attached to the flashlight, thinking that was odd
the MCPCB appears to be mounted on a thin removable shelf, not a shelf that's one piece with the body
amps seem to depend greatly on resistance - press the battery down harder on the spring, amps goes up, etc... The good thing is you could probably bump the amps easily with bypasses, better LED wires, etc.
Strap wrench didn't work on the bezel, but, I could get the MCPCB out from underneath! It's a 25 mm MCPCB, alum, and really looks like an SST-40 possible 5700K or so.
Another clearer look at the driver:
Really surprised the threaded connection at the base of the reflector was relatively easy. Usually those are fully glued, or press fit with no threads:
$19.99 USD before 2 x extra 20% off, limited 01/account.
Just received my order, very hard to open it, all glued together. Build-in battery is 3P of 18650 (no name on it), capacity around 2000mAH/cell.
I canāt open the head so donāt know type of LED yet. Driver looks well designed.
Looks very bright to me, I may upgrade batteries to Samsung or LG high drain cell ā¦
I got my everbeam E90 in today as well, I donāt know too much about lights but the UI is very simple high, med, low, strobe, sos. To turn off you hold the lighted button.
Good CRI compared to a very poor CRI light I have, maybe 5000k? the clip is alright, I have it on the tail end and it extends past the tailcap for super deep carry, pretty flimsy though and kinda pokey where it flares out to wrap around the tube.
Iām not sure how robust the rotating head is but the light has a good feel to it. It would be nice to have detents on the rotating head.
I like how it takes AA, NIMH, or lithium.
Iād rather it not have the blinky modes and instead have a slightly more complex UI with a momentary mode/lockout but for what it is the UI is fine. Also starting in low is better for this type UI imo.
Yeh, different chemistry, so shouldnāt be too bad other than overpriced even at ~2bux a pop.
For my KL02s, I got a bunch of those Li-cells with built-in converter. Theyāre low-stress enough that the cells should work fine, and when they fizzle out (or preferably before), just recharge āem.
I wouldnāt go the 16340 route with the ā02s because thereās no regulation otherān a resistor, theyād stress out the LED, and just plain overheat, in addition to having zero LVP.
The regulated 3V ones are about perfect for āem.
I still got those Morpilot ā123s⦠somewhere⦠that I could use in a pinch, or even start burning āem off rather than having them go to waste.
Damn ,this looks like a pretty DECENT light for under $30. I like the head/reflector size and throw. I have a bunch of SFT40's coming in, maybe ill grab this alpswolf and try one, and swap out some of the wires while im at it.
Just FYI - I don't know if you ever try this but i have had REALLY good results with this approach on Badly Glued on Bezels. -i have a Wagner dual temp 1200 watt (or so, cant remember exact model without going out to the barn) Heat gun, i just run it on the low setting on high output for a couple of minutes moving it aorund the head of the light. Then use think gritty rubber gloves (gardening gloves) so i dont brun my hands or scratch the bezel/head, and my success rate is well 100% lol. If you havent tried it, maybe consider. it works better than strap wrenches for me. Sometimes i have to put the head in the bench top vise after heating it, but it still works well. Ive rigged the bench top vise with high density foam wrapping jaws - gives good grip and protection
