If you look at the front of the device, there are a few ports labeled “input”
Yeah I have some high amp rates cables and PD chargers but I really only use them for things like that soldering iron I linked shortly above, computers that use PD, or things with massive batteries. I use them for my phone too but my phone automatically reduces its charge rate at night to make the charge process slow enough that it reaches 100% an hour or two before I usually wake up
I ALSO have some of those everything power-only cables ha, I agree they’re nice for forcing low charge rates on dumber devices
SIGShooter
(SIGShooter)
7448
I keep a few of the “everything cables” in my earthquake supplies since who knows what I might come across in the aftermath of the Big One.
caramba1
(Caramba)
7449
I haven’ t see any sharps lately so here we go:
If you scroll down there is one seller for 11.59
GAnzo FT759M
caramba1
(Caramba)
7450
This looks pretty sharp too:
12 inch drill bit for $2.79
Another bit of feedback on that 4pak of molle pouches…
They fit perfectly a tire-repair kit. You know, the 2 doodads with big handles (hole widener and the overgrown yarn-needle), the twizzlers, and the sealing goop.
Handles side-by-side are the perfect width to fit snugly in the bottom of the pouch.
The twizzlers fit perfectly in the inside-pocket.
The tube of goop, I’m gonna stick in a small baggie in case it leaks, but that just drops in, too.
It’s almost like they were custom designed for each other. Kewl!
They’re 18bux now vs the 10 when in sale, but still worth it if you got small doodads you want to protect or loose crap to keep together.
bushmaster
(bushmaster)
7452
Good job spotting the $12 Ganzo . I grabbed one.
SIGShooter
(SIGShooter)
7453
Hummm don’t see it on the page or on a search within Amazon. They must have bumped the price up to be the same as everyone else.
bushmaster
(bushmaster)
7454
It’s over on the right side of the page where “other sellers” are. I just looked and it’s still there.
raccoon
7455
It’s $11.95 here, from another seller:
https://www.amazon.com/dp/B06XZM7FV7
2000K to 5000K Smart Bulbs, cheapest price they’ve been for past ~2yr, 2 for $23
Globe Electric Wi-Fi Smart 10 Watt (60W Equivalent) Tunable White Frosted LED Light Bulb 2-Pack, No Hub Required, Voice Activated, 2000K - 5000K, A19 Shape, E26 Base,34208 https://a.co/d/3AsOfkP
They are a deal but I’m mostly sharing for those people like me who love CCT adjustable lighting with a warmest of the warm white. These are TRUE 2000k (color looks identical to my E21A 2000K). I haven’t taken them apart to ID chips but the light quality is nice, 5000K is nice too - they claim 80CRI
The app will be a bit much for some folks, but when I got mine I set up some scenes which I can command via “hey Google, activate daytime”, and put them on auto schedules to adjust intensity and CCT through the day. I rarely touch them now.
The build quality is okay. I’ve had mine for 4yr, they still work but after about 2yr they started to occasionally encounter FW bugs which cause the intensity level to jump around (nowadays I see it maybe once a week, lasts for a couple min, then goes away). Maybe they’ve patched this in newer ones, but I’d still buy them even with - nothing else I’ve been able to find comes close.
Also bear in mind these are wifi lights, may put some folks off.
raccoon
7458
I received this keychain flashlight just now.
First impression:
I really like it, and it’s easily worth $9.99
(I don’t know if it’s worth $17.99, which is the current price, with the 10% off discount.)
I plan to do a comparison of the RovyVon A23 to the TUNENGE light.
The TUNENGE light is probably more similar to the RovyVon A3, but I gave my A3 to my sister, and I don’t feel like borrowing it from her.
The TUNENGE light arrived mostly charged.
(It only took about 5 minutes to top it off.)
caramba1
(Caramba)
7459
5.99 This Coffee maker is awesome for strong espresso coffee.
On a hot summer day, you can just put it in your mailbox or pavement to brew. It’s made of AL so it has good thermal properties.
Ledhead
7460
VENLAB Digital Multimeter DC AC Voltmeter $4.39 with code 4EE9HEKM (techbargains) & 30% on-page discount.
azj
(azj)
7461
Dang, I have like 4 MMs right now. If I could just think of a reason for another…
SIGShooter
(SIGShooter)
7462
Doesn’t appear that the code is valid anymore.
keyzard
(keyzard)
7463
I’m slowly replacing all my “throw away” Harbor Freight meters I have stashed in vehicles, the camper, etc.
kuoh
(kuoh)
7464
I have more DMMs than that, but at less than $5, I figured it couldn’t be worse than the old HF red. Heck, I spent more than that for breakfast at McD today. Anyway, the Amazon driver had it waiting for me when I got home today. It is a basic DMM that’s lightweight with a white backlight and feels miles above the cheap red HF meters. The display is very readable straight on, but does fade out pretty quickly when viewed at 10-15 degrees above. The dial feels pretty smooth without needing to exert excessive force to turn and has very positive detents that locks in each selection with no slop. It’s obviously not going to have lab grade accuracy, but I’ll be happy with +/- 3-5%. The kickstand could be better and I wouldn’t be surprised if it broke on the first fall, but I probably wouldn’t be too sad about it given the price.
Basically, if it goes on sale again at this price, I wouldn’t wait for a reason to get another one.
KuoH
Mandrake50
(Mandrake50)
7465
I used both of the discounts…A check box and redeem radio button. $5.06 after tax.
