It’s comical they have a 5 in 1 where will it stop? But I actually kinda like it. Many lights are too low and 1 bulb just don’t cut it. I kinda want to find like a 6 pack… these things should be sold like that 6 for $20
Wellp, if you’re talking about LED blubs, it’s pretty much a given that the “60W” snowcone blubs are a dime a dozen, but they’re fairly reliable. They don’t push that much power (thus heat) through 'em, so they manage heat fairly well with the cheap Al-foil “heatsink” under the plastic-foil base of the “cone”.
Get to a “100W” bulb, though, and its almost doubling the power/heat going through them at 13W vs 7W. They also cheap out by using fewer LEDs at higher power each to cut pennies from the unit cost.
So with hotwire bulbs, 1 100W bulb puts out more light than 3 40W bulbs, so more light with 100W vs less light with 120W, as hotwire bulbs are more efficient at higher and higher wattages.
LED bulbs are essentially linear, so it flips, and you’ll get more light with 3 “40W” bulbs than 1 “100W” bulb.
So… yeah. I’d rather use one of those spiders and stick 3 60W bulbs in there if I had to, vs a single 100W bulb. Indoors, it makes sense, even if it looks retarded, using it in a table-lamp or in a 1-bulb fixture.
On reason I was and still am looking for a single-bulb solution is for under the patio where I wouldn’t want one of those spiders exposed to dust, humidity, etc. And the bulb sticks in horozontally vs hanging down vertically, so that’s way more weight/torque yanking down on the socket if something’s sticking out a foot from the socket like a gigantic broccoli of light.
In a garage, it depends which would be better.
The spider with 3 bulbs would be a gentler light, lighting up lots and lots of ceiling for that nice gentle ceiling-bounce light with no harsh shadows, but “wastes” light to some extent.
With a flower-light, you can aim each petal to throw light where you want it, eg, away from the wall and/or towards the center of the room. But you have a dark dark ceiling right overhead, harsher shadows from an almost point-source, etc. That’s one thing they never show in the pix advertising those lights. You always see a brightly lit ceiling right about the lights, no shadows, etc.
Anyhoo…
For those of you on the lookout for holster options to accommodate your 1" - 1.5" straight tube-style flashlights, take a look at this model marketed for pepper spray. It stood out because of its ability to rotate on your belt or pack strap and its adjustability.
I was forever reluctant to purchase an LT1 primarily due to the price point. $60 USD is my limit for non-USA manufactered lights, and it has to be pretty unique to get a ping on my radar to even go that high. The discount price and bonus gift reeled me in. I’ve wanted one for a long time. It was worth the patience. It’s an awesome piece of kit.
i never quite get the appeal of a lantern. i just don’t see it used any time except camping, or working in nooks and cranies. i bought a cheap knockoff a while ago, the only time i used it was when i was working on my car’s trunk. A headlight would’ve been similar result. i just don’t see the appeal, am i missing something?
You missed the part where you revised your budget because of such a good value purchase.
The only time I use my lanterns is when the power goes out. :+1:
Indeed. For me, they’re for when there’s a power outage or I need to illuminate a small area for an extended period of time, like a bathroom with inadequate lighting. Pop candle mode on an LT1 and I’m feeling fancy.
We have frequent power outages here in NE Washington and we like the lanterns but they don’t really do much that we can’t get with decent flashlights and the ceiling bounce.
I much prefer ceiling bounced light indoors. Outdoors, a headlamp or handheld light.
If I do ever use a lantern I find a way to shield one side if possible to prevent glare.
I have found this lantern to be a very nice work light because it is glare free for the eyes and can be positioned some, and of course it is also a regular lantern.
Sometimes having a pleasing area light under a sink or the area you are working is useful, hands free, and your headlamp isn’t getting knocked around and moved on your head by tight spaces or needing to be re-aimed.
https://www.amazon.com/dp/B001D937SY?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_7&th=1&psc=1
I have one also. Good for emergencies as long as you remember to keep batteries for it.
I got one of the OG Zanflare lanterns, probably two, but fiik where the other one is. I keep one in the can to use as a “nightlight” if I want a nice relaxing soak without being irradiated to a crisp by the main overhead light.
Got one of those lanterns shaped like a bewb that someone posted here and/or was a vipon not terribly long ago. That was pretty good under the patio when I went to insulate the pipes with pool-noodles. (Also why I want a bigger honkin’ lightblub down there…)
Almost hip-deep in those motion-sensing cabinet lights that can be used as a lantern in a pinch.
A few Christmases ago when (ironically) a Christmas tree keeled over and took out the block’s powerlines, that Zanflare lasted through the night on medium.
Hmm, forgot about that Nitefox(?) worklight that was cheap but worked pretty well. Battery tube w/ magnet, gooseneck, light-head.
Also in the can, I got my IF23 stuck to the hamper. Good to grab and 2click for the side-light to go grubble around in the cabinet under the sink. And the main light in case I need more oomf than the side-light can supply.
Plus, any light with a diffuser can be used as a lantern. I just remembered that during that 1-day blackout, I stuck a Wuben AA light (E-something?) with magnet and diffuser to the lamp over the catbox, so the kitties could see what they’re doing. Only needed the lowest setting, and it lasted the whole while on a moribund alkaleak.
Anyhoo, while lanterns proper are handy, ad hoc lanterns can be used in a jiffy.
Again!!!
Another set of ostensibly 40W real, “300W equivalent” bulbs, that only drew 19W and yeah, comparing it with other lights via ceiling bounce, I’d guesstimate between 2000 and 2500 lemons vs the 5000 claimed.
At least they’re in fact a nice WW vs retina-scorching CW…
So, I gently grexed to the seller, being polite and even complimentary, asking if maybe I got mislabeled bulbs, and what to do about them. Play nice, honey vs vinegar, that kind of thing.
So, we’ll see in a few days what they say. Or maybe more accurately, what they want to throw at me to make me quietly go away.
For the inflated price of “high power” lightblubs, you’d think maybe some sellers/mfrs would just make the damned bulbs to spec??
My bloom style led bulb replacements seem pretty true to spec…most other ones are typically much lower if they’re not from famous branded companies.
Just stumbled across this. I know nothing about it. My brain sez I have enough chargers but that impossibly-cute, scantily-clad, sweet-smelling young thing / gadget junkie that sits on my shoulder sez, “You know you want it.” Pretty sure she’s whispering in my ear about the charger…
MIEKLALE Smart Universal Charger 50% off at $9.99 plus 5% off click coupon.
https://www.amazon.com/gp/product/B0DK73BVRX?smid=A3A3NY82ZNU6B1&psc=1
Looks to be a simple re-badge of a Charger LiitoKala Lii-402
I’ve got a 1, 2, and 4-cell of these. They seem to work fine. Good travel chargers which I generally use mine for.
Seem to be a lot of lower reviews of this one. Quality control, or people not understanding how it works?
Is this good for anything?
Heat Tape for Sublimation, 5/10/20/30/50mm x33m(108ft) Heat Transfer Tape,Polyimide Tape for Electronics (30MM) $2.5 using code WCJ2ZKLT. Should work with all sizes. I didn’t try…
Not talked about in the listing, but polyimide tape is an excellent dielectric, in that it withstands a lot of voltage without breaking down. It also has a very high temperature rating. This used to be super expensive when we bought it at work from 3M.
Sofirn headlamp, h05B, for 12.99. It’s a sort of goofy way to get there, first click on the Amazon link, then on that page click on the light to go to the full Amazon webpage. on that page click on the 25% coupon, and it comes out to $12.99 plus tax. I’m not getting this, as I have a Sofirn headlamp that broke at the interface between the strap and the light holder. I traded several emails with helpful Sofirn. She sent me a couple videos, one which shows the same interface design. I’m also not crazy about the UI. But maybe you would like it, with red LEDs and such.
