Alkaleaks ooze KOH when they do what they do best (ie, leak), so once that dries out into a salt-block, you gotta treat it as such. Soaking in AcOH (vinegar) is what I usually do, at least as far as the tube and springs. Don’t soak the electronical parts.
Sometimes it’ll take a complete disassembly to see if anything got into the internals. Corrosion on springs and the tube and any other contact areas would need to be scrubbed clean, etc., before it could work right.
I just wiped and sprayed the PCB, etc. It was not too corroded. The spring loaded center pin was locked up tight but got it apart and as you can see the spring and everything apparently cleaned up well.
Major ID 21.05mm
Minor ID 16.89mm
OAL 38.53mm
Major ID cavity depth 25.40mm
No spring at the tail end and don’t think it unscrews.
