Andruil2 AA or AAA alkaline cell lamp
I am off travelling and also have recently bought a Wurrkos TS10 with Andruil 2, and I do like the low level aux and white light moonlight memory setting.
But the rechargeable battery will be an issue… just another bit of kit to carry… yea, not a lot I know… but I now have lots of little bits of ‘not a lot’ and it all adds up.
So looking for a small format flashlight, one or two cell AAA or AA, with aux coloured LED’s main white, Andruil 2 ( or other firmware that can do similar)
Not a critical item at all, just a nice to try if I can…Any suggestions
Just consider buying for TS10 rechargeable 14500 with built in USB-C port. Nowadays you charge almost everything in this way.
Then potentially in to a power adapter or finding a place with electric, remembering to plug it in… then unplug and take with you if in café or bar etc.
That is the sort of kit I have now, but if I can drop all that, that will be 3 coffee mug sized bits of stuff removed from my kit. Yes, not much, but I a just really trying to do everything on primary cells.
https://www.amazon.com/s?k=14500+battery+usb+c
Cables usually included.
How many alkaleaks would you plan om carrying anyway?
If you are not carrying with you a powerbank or something it is true. In this case just need small powerbank and cable which can be used for various things. Also with li-ion you get longer runtimes and at the end maybe weight-energy capacity ratio will be better.
But yes, I understand - in this manner I bought the Skilhunt H150 which I can used with Eneloops which can be stored safely for long time.
At this time the Sofirn SP10 Pro is only anduril dual fuel AA light.
Was not thinking of carrying any. Basic AA’s pretty much available all over Africa / India even where no electric apart from Genny’s
I have one solar power bank, that is A5 paper sized, 1 inch or so thick… but the solar does not charge it well.
I now see this question has been asked a few times already on this forum, so I am not alone.
There was a secondary reason too, involving an elderly friend that giving them a torch with rechargeable batteries, especially AA sized one, but at 4.2 volt instead of 1.5, would just end in disaster !
So buy mentioned Sofirn SP10 Pro and you will be happy :slight_smile:
You could order thefreeman buck-boost driver for fwaa/fw1aa and put it together :wink:
Yea, I considers that after reading the other threads , but it becomes another project then!
Will do
Thanks
Missed that reply. At work, busy, just catching up now
Also keep in mind that aux lights will only work at higher voltages, via small bleed resistors.
No boost-converter-based light in its right mind would boost 1.5V just to keep aux lights lit. That’d be a guaranteed way to drain alkaleaks to the point of crapping the bed and ruining the light.
Same with those dual-fuel lights with lit tailcaps. Only worked when using a Li cell.
Yes I now see the one I ordered does not seem to have the low coloured aux.
Like many here, I have too many torches anyway😂. Do not need another, even if it did fulfil my exact requirements.
Seems there is not one, so not an issue in the slightest ! :grin:
I think gchart did make a booster-tail at some point :crazy_face:
Adding aux LEDs is pretty easy when it already needs to boost to run the MCU.
I’ve been using a modded FWAA from thefreeman, and it’s pretty great. It runs really well with an Eneloop, including the aux LEDs… which I use to tell me how the battery is doing.
The MCU can’t operate at AA voltages, so it’s boosted up to a constant 3.0V. It then can power the aux LEDs exactly the same way it would with li-ion. And since it’s passive and uses an efficient boost converter, parasitic drain isn’t really an issue.
