Anduril ... 2?
I have a small quality of life/convenience suggestion for future releases of anduril (not sure if this is the right thread since my suggestion is not regarding anduril itself but rather the official releases of it).
Please include the model number in the .hex file names (e.g. m0712).
Currently all the .hex files only have a (sometimes lengthy, sometimes generic) descriptive name like “wurkkos-ts10-rgbaux-lowfet” or “hank-lume-x1” but unfortunately do not include the model number (0712 and 0281 respectively).
This means when updating lights (especially if you have many different anduril lights) you pretty much always have to reference the models table to doublecheck and make sure that you have the correct .hex file as there are now many cases where the descriptive name does not correspond all that well to the actual light you are updating. Some .hex files are used for multiple different lights (that is why some newer models now have more generic names, like “hank-lume-x1”).
My suggestion would be to include the model number in the format “mXXXX” (e.g. m0712) right after in front of the release date (either with or without the descriptive name).
currently/old:
anduril.r2026-10-26.wurkkos-ts10-rgbaux-lowfet.hex
new:
anduril.m0712.r2026-10-26.wurkkos-ts10-rgbaux-lowfet.hex
or
anduril.m0712.r2026-10-26.hex
This would make the updating process more convenient and streamlined.
→ perform version check (15C) → light blinks model number → select .hex file with the same model number → flash
Of course the models table can (and should) still be used as reference (as sometimes manufactures ship lights with the wrong firmware), but for simple update jobs you don’t have to doublecheck all the time anymore.
Plus as a small added benefit the .hex files with the model names in them would be the same order they are in the models table (due to the alphabetic sorting) which makes finding the right one quicker.
I think this change would not only add convenience for those of us with many anduril lights that like to keep them up to date, but it also could help reduce confusion for newer users that are flashing lights for the first time.
Obviously you can just rename the .hex files yourself (which is what I have done for the last few releases of anduril), but of course it would be more convenient if they already came with the model number so you don’t have to manually rename a hole bunch of files every time there is a new release :grinning_face:.
Edit:
On second thought it would probably be even better if the model number was in front of the release date, that way it is exactly the same (same order) as how you receive the information from a light when performing a version check (on anything with anduril from 2023-05 or newer where the version check format was changed to NNNN-YYYY-MM-DD).
That’s a good idea.
A few lines of shell script later, I have it working.
Also added the ability to filter by model number at build time. Like, instead of make lume-x1-c, the user can now do make 0283.
12 Thanks
Will anduril 2.0 work on an attiny85 chip? Like can I just flash this to a an E-switch Fet driver?
Yes, however depending on which features are enabled, it may be too large for a T85.
Also the .hex must be built for T85.
The MODELS file will tell you for which MCU the targets were configured and built.
Each build target is modified and calibrated to match the specific hardware it will be running on. There isn’t a single anduril2.hex that you can just flash on any driver. There are about a hundred different anduril.m1234.r2026-11-03.brand-model-variant.hex files designed to run on a hundred specific drivers.
In general, the hardware enablement process involves creating a new build target for each new type of driver, containing the code and configuration necessary for that hardware.
