another help me with a thrower thread - I know I know
So, I’ve been searching through threads on here for a while and reading up. To be honest, I have information overload. Unless I just missed it, I couldn’t find one of the 5000 which thrower for me threads that covered exactly what i am looking for.
I have a several Trustfire XML C8-T6 5 mode CREE 1000 lumen flashlights. They haven’t been bad lights at all, but from reading up I can do much better. I have never modded a flashlight before, but I am a competent solderer as I build game cameras which involves soldering 30ga wire on Sony digital camera controll boards.
My situation is where I hunt, our main field is 1100 yards long and 150 yards wide. We have a huge population of wild hogs. A couple years ago, before I began reading up on lights, I bought a VRL-1 Varmint Light in red which has been a good light as well. However, I think I can get something better.
What I am looking for is complicated. I would like to have a few more budget lights that will throw further than what I have now. I may be unrealistic in my following requests/requirements. I’d like to be able to visualize hogs at 500 yards. Their eyes don’t shine so it needs to be able to show enough of the animal that I can put the flashlight on a rest of some sort and use my 300 Win Mag to make a shot out to 500 yards at night. The light will also see time on my AR10 in 7mm-08 or my AR15 300 blackout, so it needs to be able to handle recoil. It would be nice to also be able to put it on a low power and use it on Mossberg 930 12ga shotgun for close up hammering of hogs, but I can always use a different light for the shotgun if necessary. I’m not as concerned about weight, but as always the lighter the better. It needs to be able to be attached to the rifles, so it can’t have an enormous head on it or side by side batteries. I use offset picatinny mounts, so it can take a decent size head on the flashlight, just not spotlight size. I have plenty of Tenergy 18650’s at home so I’d like to stay with that format. I’ll need to buy some Panasonics I guess. The only reason I have the Tenergy’s is that I’ve had good luck with their AA’s and Eneloop AA’s in my game cameras. I am looking to buy 3 flashlights, so it’d be nice if I could get the lights for $50 or less each. I only really need 2 modes, High and Low. I don’t need a pressure switch, just a tailcap clicky button. It needs to be fairly waterproof for the occaisional rain, but it’ll never be submerged unless I drop it in a puddle. Please list what cheap easy mods for the lights can be done to make them better. Also, are there any options on a better red LED light than my VRL-1? I’m not unhappy with it, I just need a second red light and don’t want to spend that money again if not necessary. Any and all help is greatly appreciated.
The longest throwing light that has a chance of rifle mounting is a Maxtoch Sniper available at mtnelectronics.com
BLF member mudgripz is a resident expert on this. He’ll likely recommend a MaxToch…excellent lights.
I’ll try to link a few of the relevant threads on this subject. They will be a little more than your budget, but well worth the $.
I’ve looked at the Maxtoch M24S’s. I read up on them and they seem to be a good light, just wanted to try to stay a little cheaper if possible. If there aren’t any other options, I may have to just settle on 1-2 of them instead of the 3 lights I need.
Just because I’m adventurous, is there a host that I can just build up for a reasonable price that’ll meet my demands?
If you're open to a "zoomie", I would take a look at the Uniquefire UF-T20. It mounts easily to a weapon and is heavy duty. Swap out the driver and emitter to the ones of your choice and you'll be in business. With a dedomed XP-G2 or domed XP-E2, they throw pretty well. I think that for a hunting light a reflector is still the best bet since you don't have to fiddle with zooming the light, but you do get a lot more throw for the size out of a zoomie.
I’ve been getting guy’s (especially hog hunters) setup with jacob A60’s using white XM-L2’s or red or green XP-E2’s. (Also built one for a guy with a red PH-54 for more lumens at a cost of throw).
Another light I would suggest, tho it would take some fiddling to mount, would be an HD2010. The HD2010 with dedomed XM-L2 will allow you to shoot to around 3-400 meters. Actual throw will be much more technical but the “F1” standard distance is no where near enough light to shoot to so that spec will be pretty useless to you.
With XM-L2’s in an A60 expect to shoot out to around 5-600meters and with a red or green xp-e2 out to about 650 but note there will be VERY VERY little side spill with an XP-E2 cause of just how efficient the reflector is at making a tight spot.
I have some single color LEDENGIN emitters ordered to build some hunting lights. They have much larger die’s that XP-E2 colors so I’m hoping the beam will be similar to white XM-L2’s, only thing is they can’t be dedomed.
