05/31/2014 - this deal Is a No-Go because of shipping costs. When I first priced it out, I got a much lower shipping rate of about $5 - now it's $25. As an example, I ordered the DIY "Copper" C8 pill from them a few days before I found this J19 deal. Cost was $3.30, shipping was 21 cents. Now If I were to order the same pill, the shipping cost is $1. They increased the shipping costs dramatically right after I checked this.
Buy this TrustFire J19 light here: http://www.dealsmachine.com/best_174512.html, use promo code: "dealsmachine" for 10% off up to end of May. My total cost with shipping comes out to $53.74.
Since this light is a 3S big cell conventional with 3 LED's, a zener modded FET based Tiny13a driver would be the hot setup. Potential is about 6A per LED.
Add 3 XM-L2 U2 1A's on Noctigon's.
The driver should be the same one Richards packs in the Super Shocker, here: http://www.mtnelectronics.com/opencart/index.php?route=product/product&path=80&product_id=235. You can build one up yourself or maybe Richard would sell you one, all configured and loaded with the firmware.
I'm guessing about $90 invested at most (~ $20 for LED's on copper, ~$16 for the driver), or about $76 at the least to get a 5,000+ lumens big light that can throw pretty well. Maybe it can't throw as well as a Super Shocker, but should equal it in lumens, plus this light has the advantage of using 26650's or 32650's for much better runtime.
With 3 32650's from FastTech, another $36, little cheaper at WallBuys. These cells would have great runtime (relatively), but sacrificing a bit on the amps and resulting lumens. These cells have gotten decent reviews. 3 unprotected button top King Kong's would be the best performance in the 26650 form factor most likely.
This would be an interesting mod build with the cost savings on the J19 host at that great price. Of course you could select tint, or de-dome emitters for better throw - lumens reduced accordingly.
Why I like this setup:
- relatively cheap, compared to modding a Shocker
- looks like pretty good heat sinking - can run longer at high amps
- decent battery capacity, up to 3 6,000 mAh cells
- nice combo of total output and throw (guessing 5,000+ lumens domed, ~4,200 de-domed and ~350-400 kcd throw)
- better balanced than a Shocker
- I'm guessing with using a zener FET based driver, you will get excellent efficiency out of the batteries (no buck or boost)
- with a Tiny13A based driver, lots of flexibility of custom mode configuration
Only thing lacking may be availability of an AR lens, but could probably get a UCLp made to fit. Chris at FFL will do custom sizes of UCLp's for no extra cost.
Or, wondering, if you wired the 4 outer LED's in two groups parallel, then make the center LED by itself, use 3 cells and you got it, but the center LED may get twice the amps the the other LED's do. Wonder if that would work?
