Any Floody Headlamp recommendations?
I used to have a Spark ST6-460NW but I somehow managed to misplace it. It’s probably around the house somewhere but it’s been missing for months so I think I need to look for a replacement.
Requirements:
Must be floody. Best if it includes a frosted lens or if a frosted lens can be purchased for cheap.
Must be neutral/warm white. ~4500K?
Waterproof 2+ meters
Nice to have:
Single digit lumen low mode
Low battery warning
18650
I kind of want to get a Zebralight H600Fc Mk IV. But I’m hoping to find something with better value (i.e. doesn’t cost a kidney.)
Have you looked at the TH20? It might not be floody enough for you, but it has a nice wide spill around the hotspot. Also has adjustable brightness from 1.6 to 250 lumens which I love, in addition to a firefly mode and 500 lumen turbo(only on 14450, AA turbo is 252). Despite that bunch of modes, the UI is very nice to use.
The Manker E03H, I haven't used it but I will order one soon. It comes with clip on diffusers and seems to have nice mode selection, and you can set the moonlight mode to a level that you like, through a special series of clicks. Don't know about the spill. You may find the headband uncomfortable, but there are others that fit, I believe.
The Zebralight H302W was the best flooder I ever ordered! I always wanted its big brother the H602W but never got it and now it’s discontinued. That little H302 puts out such a flood it always amazes me, such a tiny little light.
… find a way to afford the H600Fc Mk IV or similar, or previous discounted models on Zebralights site.
Acebeam H15 XHP70.2 is the brightest and floodiest headlamp I’ve seen. However, the NW version is probably a little over 5000k so is a bit on the cool side.
You can always put DC-Fix on the lense to make the beam smoother and floodier.
