I don’t really see this kind of set up much. I usually see either a single 18650 or four set up. Single or multi-emitter doesn’t matter. I realize the multi-emitter would raise the price, but even a well driven XM-L2 should get you close to 1000 lumens, right? Don’t care if it’s a flood or thrower. Just a bright, reliable 2x18650 under $30. I reason why I opt for 2 18650s is for increased runtime if it’s a single emitter driven hard. I just haven’t seen anything like that.
The Convoy lights + extensions would fit the bill. You can get a 2*18650 Convoy C8 host for like $14. L4 light for under $40 if you want an electronic switch and don’t want to assemble one.
I don’t know if you’re in the USA, but bought one and its a good light for the money. Tailcap for power on/off and a side switch for mode selection, no mode memory when the light is turned off. Proud forward clicky tail, big reflector, single XM-L. Driver is 5-mode and 6W, it draws about an amp off the two-cell stack.
The driver is impossible to resistor-mod though, I tried every single large resistor and it did nothing.
Seems pretty good. Actually, it’s kind of hard to believe the price, and I’m sorry that it’s out-of-stock now, because I wish I had bought a few more at the time :(… Also, it looks like the latest review might be by one of our BLFers…
Have any of you seen or used the Small Sun zy-t07? Granted, it’s a bit uglier than the t08 with the two individual battery compartments and the beam has shadows of the screws from the bezel…. but the estimated lumens are higher.
Stepless Adjusting Cree T6 5-Mode 1200-Lumen Memory White LED Flashlight(2x18650 Not Included) From PowerFlash
Features:
Emitter Brand/Type: CREE
Emitter BIN: T6
Color BIN: White
Total Emitters: 1
In the open position flashlight, hold key open and don’t let go of, flashlight brightness from high to low or high by low to change, brightness to provide customer satisfaction levels of a key to loosen.
Battery Configurations: 2 x 18650 batteries (not included)
Voltage Input: 3.6~4.5V, 4.5V max
Switch Type: Clicky/Clickie
Switch Location: Tail-cap
Modes: 5
Mode Memory: Circuitry features mode memory
Mode Arrangement: Hi > Mid > Low > Fast Strobe > Slow Strobe
Circuitry: Digital regulated 3000mA current output
Brightness: 1200 lumens maximum brightness (manufacturer rated)
Runtime: 100 minutes (manufacturer rated)
Lens: Coated glass lens
Reflector: Aluminum smooth / OP reflector
Stainless steel assault crown
Carrying Clip: Included
Carrying Strap: Included
