From the Enlan EL01? It’s an awful logo. Thanks!
Micromesh? That way you can have a nice finish too.
Sand it with #600 wet paper or bead blast it.
I was hoping to get an older model when I ordered my Enlan Bee, just to get the Enlan logo instead of the Bee logo. I got the Bee logo of course. To do it right, stock needs to be removed over that entire side of the blade to reach the lowest point of the logo itself. Sanding it down with 220 grit then progressively finer grits is technically the correct way to do it. Not easy though.
Or, you could use the old rustler tricks and tweak the logo to read something else, utilizing the marks already present to complete a design more to your liking.
Those PacMan e’s are atrocious! But the blade is cut so clean I really don’t want to mess with mine, so I’ll just tune up the edge and leave it alone til it gets some damage to it and needs dressing, then we’ll see.
You summed up my thoughts perfectly, haha. What were they thinking?
When I got my EL-01 I was a little bit disappointed it didn’t have a Pac-man “Bee” logo! :bigsmile:
There is a product called “Bee Go” that works wonders for removing bees…
I use a buffing wheel on my grinder with the green honing paste to remove logos and other etched decals. It will also polish the blade to a mirror finish with looks pretty slick.
it will also take a moderately sharp knife to shaving razor sharp in about 30 seconds as well !
I used my Lansky hone on my EL-04 today, it seemed to be pretty sharp but I want to touch up the edge on the hone to get it where it’d be easy to keep sharp. Boy did they get the geometry wrong! On the “Bee” side the pivot or inside of the blade wasn’t far off, but out towards the tip the grind had to be cut pretty far back towards the blade. On the other side, it was much worse! The entire edge on the clip side was off centered and took quite a bit of work to get it right.
Over all, I spent about 2 hours getting it perfect.
Cut the edge to a 25º Utility angle, starting with a 120 grit stone and working my way up to 600, then honed it with oiled leather. It’s definitely a straight edge razor now! It’s first cut was one of the big straws at McDonalds, I usually use scissors on my Leatherman to cut the straw down in my 5 year olds drink so he won’t end up spilling it tipping it real far with the long straws. I opened the tip about 3/4”, slipped it over the straw, and closed the blade. Sliced that straw like a laser!
Gotta love it when they put zip-lock slides in everything, lol. (meaning a razor sharp knife makes things seem already cut, just waiting to be separated at the seam)
I’ll see if I can get a good macro picture of the edge…
Grab a cheap belt sander like this:
http://www.harborfreight.com/1-inch-x-30-inch-belt-sander-2485.html
and a couple of these belts
and a leather stropping belt to use with the above honing compound Woodworking Hand & Power Tools & Accessories - Lee Valley Tools
You can do what you described above in about 5 min and have the edge a lot sharper. When you have a lot of knives its the only way to keep them all razor sharp. I gave up on hand sharpening years ago, plus i really like the mirror finish on the edge:
And at the same time keep my fingers. As far as that goes, there’s no such thing as a lot sharper than what I did today. A scalpel is a scalpel is a scalpel. And it’s mirror finished as well. By hand.
I might be weird because I enjoy hand sharpening, and the idea of using a grinder or belt sander quite frankly terrifies me.
That’s why I like the Lansky hone, precise angle in an easy to use format that gets it right…every time!
I need a new diamond hone though, the last 15 years has worn my coarse stone down to almost fine. ![]()
im feeling uncomfortable here… less of this talk about “getting rid of bees” ![]()
Would BeePee remove it?
Perhaps we can focus on the PacMan “e’s” and leave the B alone ![]()
Polish it with sandpaper of 2000 or so but the full blade not only the “Bee”.
