Any info on this zoomie?
This model of zoomie is new to me: http://www.ebay.com/itm/UltraFire-CREE-XM-L2-2000LM-ZOOM-Rechargeable-18650-Flashlight-Torch-Charger-/371010065971?pt=UK_SportsLeisure_Camping_LightsLanternsTorches&hash=item5661ec5633
Any reviews in it here? I don’t recall seeing this typ of zoomie host before, and as it sold as UltraFire No Name I can’t just do a search for it here. Of interest to me is how wide is the beam when adjusted to widest, and how waterproof it is.
it claimed to be XML2 but the 4th picture it shows an old XML emitter… i dont think so
just another crappy crap you might need to avoid.
I don’t have that particular one, but I do own one of somewhat similar design. Mine is AA sized and has no recharger, but the focusing mechanism and general shape of the light is pretty much the same. My impressions:
1. Big - even though it was AA sized the light was much larger and longer than a Sipik 68, without being any brighter.
2. Poor heatsinking - Instead of a simple push-pull like the Sipik 68, this light used a rotary dial type zooming mechanism. You can see it as the silver ring in your picture. Turn that dial to cycle the zoom. The lens and bezel don’t move. Instead the star is on a moveable platform that moves up or down as you turn the ring. This means:
(a) Heatsinking is going to be non-existent. Because the star is mounted on a moving platform, it will have virtually no thermal path to the exterior of the light. Expect output to decline rapidly unless the LED is very underdriven.
(b) Lots of mechanical parts to wear out. The gears and other moving parts in the rotary mechanism might wear out. Same for the wires from the driver to the LED, which flex every time the zoom is cycled.
© Not waterproof or water-resistant. This isn’t too surprising as most zoom lights aren’t water-resistant. For this one the control ring is mechanical and opens into the light.
Personally, I very much dislike this style of moving LED zoomie. It’s large and useless for modding.
Thanks for the input. I did notice it was an XM-L but as I would be replacing it with other internals I didn’t really care.
I did see it was a twisty, but was not sure of how the zooming works. Thanks for the explanation, it doesn’t sound like anything I’d like to waste my money on.
