Any machinists able to work and anodized titanium?
Looking to get a custom host made, but I want to use ti so not really sure who I should ask.
Are you sure you can afford it in the first place?
It will cost like $500-2000 for that depending on how big you want it.
Pretty steep, didn't think it would be that high. Do you know how much it would cost for a C8 sized host?
Definitely over 500.
Maybe look for someone or some company that already sells titanium lights and maybe you can find one you like that’s between 250-500.
CPF has a lot of custom flashlight sellers that do exotic metals.
Thanks alot, definitely didn't think it would cost so much
Yeah sorry m8 :frowning:
Texas Lumens here may be able to help.
There is a lot more time in making a flashlight host than you think. I would say Enderman is pretty close with the estimate. Even if you wanted it made out of aluminum, I wouldn’t really want to try it for no less than $250.00. That’s probably less than $10 a hour when you figure all the time associated with just this project. A CNC machine could make quick work of it and be reasonable cheap if you wanted a hundred or more. Then someone still has to design the light in CAD software to make a file for the CNC.
Buying a host already made is probably your cheapest option.
Price of Titanium in 1.5” https://www.onlinemetals.com/merchant.cfm?pid=6781&step=4&showunits=inches&id=180&top_cat=1353
Thanks for the advice everyone
Yeah, CNC is faster but requires time to program first, so it’s a good option for the guys that make multiple lights.
A one-off is far more expensive than a limited production run or mass production.
Also the anodizing will cost at least $100 on top of that.
If anyone want to try it, pm me, I can get it much cheaper.
I machined some Ti scrape blocks for my truck a few years back. Just one simple cut on the bandsaw and 4 holes drilled and countersunk on the mill. No way I would want to try to tackle a flashlight.
Just curious, but what would a simple 1S extension for a 32650-based cost in aluminum?
And reading this conversation makes me wonder how the Chinese can make lights so cheaply - I’ve seen the huge Imalent DX80 go for $229-ish.
It’s only really expensive when you’re doing a one-off because of all the one time costs. Things are just far more cost effective in bulk it increases the profit margins dramatically.
It is a wonder when you hold something like the BLF Q8 in your hand and wonder how something could be sold for as little as $50.
