I’m new to the hobby and want to definitely ease into this modding process. That said, I have my first LED, a NiteCore EA-41 en-route to me.
I want to KISS for starters and do basic maintenance improvements, then later work my way up and try some of the more technical enhancements that most here excel at.
So for starters I was wondering if anyone here has modded an EA-41, and what have you done?
Not even seeing one yet, I dunno what basic simple improvement I can make, or need to be made.
Some simple improvements I was considering are:
Heat maintenance/improvement by filling the gap btw the heat sink and body with foil/metal strips.
Adding thermal paste and or adhesive where needed eg. threads, around LED area and driver.
Sodering copper braided wire at the tail spring and spring at the heat sink piece.
General thread lubrication with super-lube or other.
Lubricating all “friction” electrical contacts (including the batteries) with De-ox-it.
The above improvements I gathered from research I did over the past few days, but I have never attempted before. If anyone can help out with the what, where and how to do these basics I would certainly appreciate it.
I would just say good luck m8, and please post pics if you do get it apart. A lot of people would be interested to verify the innards of the new EA41.
The only disassembly threads of Nitecore lights I’ve seen were locked shut with glued threads.
I’ll see if I can find the EA4 disassembly thread, that should help you along… Blehh, mind isn’t functioning properly… Not enough sleep, can’t seem to find it
As You know the EA8 is the big brother to the EA4.
And the the EA41 is the new version of the EA4.
Have a look at the following threads posted by Old-Lumens:
Nitecore EA8 tear down - Modding will be later and in a different thread. | BudgetLightForum.com
https://budgetlightforum.com/t/-/17922
The other half of the comparison thread - Modding the Nitecore EA4 - It's DONE and Beam Shots are up! | BudgetLightForum.com
https://budgetlightforum.com/t/-/19088
Another Nitecore EA8 to Mod, haven't I done this before? Finished, Beam shots are up | BudgetLightForum.com
https://budgetlightforum.com/t/-/22143
Makes me wonder what has changed to support the 20 minute turbo run time on the EA-41. In fact after browsing the links you sent, I sent Nite Core an e-mail asking if they changed the heat sink characteristics from the EA-4.
My 41 should be here soon, I did pick up a flip up Butler Creek Blizzard scope cover. Now to get a piece of photo gel to cover the flip up lens.
Thanks CRX. That’s good stuff, and this would be a simple mod for me to handle for starters. I do like the clip you added. Having not seen my 41 yet, I can only assume there are no issues with the battery clearance in the tube.
