hello all
I am on my way to make a charger with TP4056 Charging Module my question, have any one tried the TP4056 from Fasttech ? and is it really charging with 1A if given a 5v 1A source ?
hello all
Yes I have one coupled to a 18650 holder, they work great, there’s a set resistor to alter the charge current, as standard they’re pretty close to 1A if I remember right.
The cut off current is 1/10 charge current, so even if set to a low current for a small cell it’ll still terminate correctly and not finish early.
The only thing to note is isn’t enough heat sinking if input voltage is greater than 5v,
I tried mine on 7volts and it didn’t charge correctly, IC too hot.
HTH
As with all chargers, there are losses. If you have a 1A li-ion charger, it will need over 1A 5v usb source to make up for the losses.
The TP4056 actually charges at around 850mA. A 1A 5v usb source is enough for it.
ty that is all what i needed to hear
