Any single 18650 light that is better than Fandyfire HD2011?
HD2011 is very bright, like the floody beam. And I like its compactness, suitable for EDC. Now I’m looking for another such light, no budget as of yet, just wanna see options.
Xiaozhi? Zebralight SC600?
Roche F12? Convoy S2/S3?
I have this one, but I EDC it’s twin brother the XP-G2 R5 2B 1.4A 3 mode in gray from IOS.
This one seems impressive, I don’t know how floody it is.
http://www.crelant.com/a/English/Product_series/7G%20Series/2012/1122/43.html
How about a Ultrafire 2100?
Their all much of a muchness, put an xm-l in a tube, drive it at 3a fit an op reflector, there’s only so many ways it can go….
Your choice is really in the modes and the led tint, in that case I’d go with the xiaohzi in a t6 3c tint or look at the convoy edc lights from fasttech. Otherwise your spending a lot on a zebralight for the UI or an eagletac for the size.
Your other options are size ie cell type, or look for something with an xp-g/xp-g2 for more throw.
I like mine but it's not any "better" than the HD2011.
I actually prefer my HD2011 because it's brighter and it kind of tail stands. I say kind of because it doesn't tail stand very well. However, the 2100 doesn't tail stand at all.
Narrow down what you want. In terms of beam profile, run time, modes and UI. Most flashlight makers use the same LEDs but will vary in tint and output. So it’s more the other features that matter.
If you can wait a little for Ric to get them back in stock, give the DQG 18650 a look. Its the smallest made and a true EDC 18650 torch.
http://www.cnqualitygoods.com/goods.php?id=1857
Xiaozhi/D4
The Roche F12 is a very popular edc that comes with a decent driver and in a nuetral white tint, along with driver options.
I’ve been meaning to get one of these for a while, 2.5A at China quality goods:
http://www.cnqualitygoods.com/goods.php?id=1545
Fasttech has them at 1.75A
I prefer this design to the other budget edc’s out there, although the Roche has a tight tube and may have problems fitting some protected batteries.
yup i was gonna say the roche f12. i got the 2.5amp from cnqg. i also have the hd2011.
the roche f12 throws further, but has a little bit less flood. its also a little bit brighter and have a warmer tint. and the build is superior over the hd2011. feels much better in the hand, oh did i mention it can tailstand.
and of course there is the e1320 modded 2100, but thats only available through him.
i have two of them, one maybe offered for sale if your really interested.
The CNQG Desert Yellow Roche F12 NW 2.5A costs $24.50 and there’s extra shipping cost of $2.93 just for normal airmail, or shipping of $5.46 for Registered Airmail. So in total it would be $27.43 at the minimum
Is the extra money worth it for the 2.5A? Or should I settle for a $22.79 1.75A version from FastTech
I just got the S3 recently, and I now prefer this a little more than the HD2011. Build quality is better, unlike the Roche F12 there are no battery fitting issues as I’m using the protected panasonic 3400’s that are supposed to be very large batteries. Beam profile is slightly floodier than the HD2011, and has a slightly larger spill, but otherwise very similar. The S3 also comes with a NW tint which is much nicer on the eyes. I have the Roche F12 on the way, be interesting to see how it compares.
I have both the Convoy S3 and HD2011, and yes the quality feels better. (After all, the Convoy S3 was twice the price of the HD2011!). I like both. HD2011 has a larger spill to me, though.
what about which one is brighter between the two?
did you get the 2.5amp roche f12? that is the brightest tube light i own that takes a single 18650.
The hd 2011 i have pulls over 2.8a bog standard(sorry my son has ) :smiley:
Do you have the XPG version of the S3? That might explain if the spill of the HD2011 is bigger, otherwise the spill of the S3 is definitely larger on my version.
I can’t say what it’s like compared to the others, but the Xiaozhi is built really nice. The NW is a great tint. It puts out a ton of light and the low is a good setting. Being able to get rid of the epileptic modes is a bonus too. The medium could have been a little lower, but you can’t have everything. I like that it does’t try to be a thrower at all. It’s just a very bright flood on high and compares with the best that I have for a small bright well tinted flood. On low it’s perfect for little indoor stuff. Although I just got it I can tell it’s a real keeper. It’s a very large hotspot that when shined out a ways becomes almost not there. It’s really just one very smooth non-ringy flood. Which I like a lot. I really can’t stand lights that are ringy at all. I don’t want to see any hot spot on a flood if possible. I would give mine 9.5 out of 10. With the only deduction being the medium mode being set a little too high.
Two thumbs up for the Xiaozhi.
I got several EDC's, and for some reason, I like the beam of the 2011 best - widest, wider than the Xiaozhi, wider than the IO EDC, wider than the UltraFire EDC host FT sells. Don't like the host much - too smooth finish, looks cheap, no separate pill - pain to mod, but it's the highest lumens output at the same amps, and widest flood. Think it has the most coarse OP and the reflector is shallower than the others which explains why the beam pattern is wide.
Hi Tom E, do you have the IO EDC (convoy S3) XML version or XPG?
