Any small buck drivers for driving 6V XHP70.2 to 6000 lumens?
This is for a project of mine. I’m going to modify a flashlight with 3 XHP70.2’s driven to 6000 lumens with 3 26650’s in series, so they’re gonna have to be something along the lines of 8.4v-16.8V to 6V ones. So, individual drivers for each one, drivers set in parallel. Are there any drivers that can handle those amps for say 5 mins at one go? I don’t expect size to matter, but expect to keep them to under 25mm. Thanks!
LD-29S @ Kaidomain
May work by reducing the sense resistor value. Sense voltage is 60mV (3A on an R020). At least the diode is 10A rated. Can't say for sure if a single LD-29S could provide all the power you require per emitter, but two certainly will. Problem is the driver doesn't seems to have grabbed much attention. Pity, as the good old LD-29 still is a driver of its own class for driving 1S emitters with 2S/1S cells.
The coil will get pretty hot at 10A, I don’t think it’s made to drive that much current. All coils built for 10A are bigger, so the inductance will drop significantly. If it’s possible, go with 2 boards per led.
if that’s the only way then i’ll do 2 boards per LED, but say i reduced amps to under 8 amps. i figure the 4.8A recommended would be plenty bright already so maybe maxing out at 6A… Would that driver manage it for 5 minutes at least?
I don’t know, you will have to test it…
With regards to the current handling ability of LD-29S' coil, I agree with Schoki, though it'll probably handle 5A or more continuously. Bear in mind there are other factors like the increasing switching output ripple which affect signal quality and can end up being pretty bad for the emitter.
With regards to inductor size versus its current handling ability, look at what a relatively compact R60 I desoldered from an old motherboard can manage:
Your figures do not seem to have much sense to me R10500. With 2 boards per led, you'd have 6A on high per emitter. You then said:
Reduced amps to under 8 amps?
If the driver's heat path is adequate, it will probably handle 6A of current for 5 minutes. You could also upgrade the inductor for higher peace of mind.
Cheers ^:)
uhhh that table just completely confuzzled me haha is that a sign that i should leave the modding till i’ve understood more? What i’m looking for now is just a driver that won’t ever burn out if i wanted it to provide enough power to a 6v 70.2 to reach a max of 6000 lumens, and it must be a buck driver that can work with cells in 3S. I just read about this driver HX-1175B1 but it appears to have been long discontinued so i’m lost again!
