Well, I need to flash a different firmware on some S2+’s. But the problem is I just noticed that pills are glued, so I can’t access Attiny13A chip.
I already tried to open with a force but no success. There are some nasty stuff inside.
I would leave it alone but I have multiple flashlights from same source that are same way.
Any suggestion how to open it?
I love the notches in that pill! Not from FT I assume. Heat usually helps a lot. Mini torch or lighter. I’d suggest placing the LED end down on a damp cloth to prevent/reduce damage.
I would try cranking up power on the soldering iron and applying heat to that ring, then give it a twist. The heat usually helps adhesives release, but not always. Good luck!
You're probably using tweezers in those small holes. Can you enlarge them with a small drill bit or rotary tool enough to try needle-nose pliers?
I think acetone degrades epoxy, if that's what it looks like.
Who's selling these glued lights?
