I’m hoping that there might be some chemical out there that can do the job without compromising the anodized finish. Is my hope in vain?
Thanks ![]()
Thanks ![]()
I believe most are laser etched and removing without damaging the ano is futile. I hope I am wrong but I dont think so. :(
I have tried just about everything and the most luck I had has been to use black sharpie and color in the logo and wipe the excess off the body.That said it's not permanent or really effective because it wears off sooner or later.Most lights logo's are laser etched,where a laser creates microscopic pits or ditches thus removing metal to create the logo design.Look at one using a manifying glass or loupe and you will see what I mean.edit-johnny mac beat me to it!
I think you're right. Greased Lightning will take it all off though. :)
Considering logos are not damaged by “baking” I don’t think it will be easy to remove without damaging the ano.
What logo don’t you like? Uranusfire?
LOL. No. If I had a light with Uranusfire printed on it I’d want to keep it that way just for laughs.
My beef is with Solarforce. Sometimes when you order bodies and heads separately, the print on the head does not line up with the print on the body, so what I’d like to do is get rid of the stupid “Caution! Hot Surface!” nonsense. Such things really bug me.
You could always have the parts Cerakoted. That seems to cover up most logos.
Dremel… you could add fluting or extra knurling while you’re there. ![]()
Easy Off oven cleaner
Dilute etching acid- could also possibly used to change the appearance of the entire tube- sort of like baking. The made etching acid for PCB’s that might work.
since we seem to have preponderance of batteries available- what about some home electrolysis? :cowboy_hat_face:
Seems like an interesting possibility. When I tried Easy Off oven cleaner it took everything off except the underlying logo. Maybe all logo’s aren’t the same (likely).
Stick your own printed label over it.
It’s not going to happen. I wet sanded the logo on my SkyRay3800 for hours hoping to remove it while leaving the anno intact. I got all the way to bare metal and the stupid logo could still be read. That was a printed logo, no hope for a laser logo.
