Hi,
I just got one of these Niteye MSA20 (2xAA) lights from IS:
http://www.illumn.com/flashlights/niteye/niteye-msa20-xm-l-u2-300-lumens-2-x-aa.html
and it is very nice. It’s not bad on 2xEneloop AAs, but FYI, I also tried it with a 1xAA dummy and a 1x14500 (protected Eagtac) and it is even brighter. Note that it’s only spec’ed for “2-3.2V”, but according to this older review of the MSC10, which I think uses the same driver, etc. (Object/Subject Review: Niteye MSC10 [In Progress] | Candle Power Flashlight Forum), 16340s are ok, so I figured I’d try the 1xAA dummy + 1x14500 combination, which seems to work (including the dimming).
Anyway, this comes with an XM-L U2 emitter, and I’d like to try to swap the emitter for an XM-L2, but I can’t get the pill out of the head or the bezel ring off, so I was wondering if anyone who has an MSC10/MSA10, or MSA20 (any of the “MS” lights) has been able to disassemble the head successfully (and without damaging anything)?
The pill appears to be screwed into the head from the battery end, but there aren’t any holes or anything to use tweezers to unscrew it.
Thanks,
Jim
EDIT: Adding some pics:
Bezel ring:
I have several other Niteye lights, and I’ve always suspected that they have some special tool that fits into the notches in their bezel rings.
Pill/battery-end (scratches on the PCB are from my trying to turn/unscrew the pill using a pair of tweezers - no luck there):
EDIT 2: No responses yet, but I’m thinking that that brass ring is a retaining ring that is holding the driver board in the head, so I’m thinking of trying to drill a small hole/notch on each edge of the ring so that I can try to unscrew the ring using tweezers….
Comments?
I guess the thing that I don’t understand is how the heck they screwed that in in the first place, without such holes?
