Stock I assume?
(I don`t have either of them, just asking)
I havent seen either of those but Im eyeing the TN32 for this exact reason.
Based on numbers by Selfbuilt:
TK61: 1000 lumen and 171 kcd
TN32: 1650 lumen and 191kcd
Basically, TN32 have slightly more throw, and a lot more output stock. I would say its the better thrower. When comparing stock vs stock.
On the other hand, TK61 are not much behind in throw considering the much lower output. So the beam on the TK61 is narrower, due to a larger/wider reflector. TK61 will be the "better thrower" if you look at runtime vs heat and throw distance.
The brightest modified TN32`s seems to around 450-500 kcd?.. Modified TK61, 600kcd, or a tad higher. This says something about the potential of the lights. About 20-30% higher kcd from the TK61. And based on numbers I have seen, the modified further throwing TK61 is not driven as hard. So it might be even more potential in the light..
Thanks for the statistics.
For throw? TK61, for better run time? TK61, for easier on the smaller hand? TN32 ![]()
Link to gopajti beamshots at 60m for X60,TK61,TN35,TK76,RC40,Nova MM15,plus more.
Its also interesting to see weight comparison:
Fenix TK61: Weight: 605.7g (790g with 4x18650),
Thrunite TN32 (XM-L2): Weight: 655.9g (808g with 3x18650)
TN32 is a smaller, yet heavier with 3 batteries than the TK61 is with 4. And TN32 is driven way harder to achieve quite similar throw number.
I believe TK61 is capable of lighting up something at 800+ meters (ANSI FL1) for more than twice the amount of time compared to TN32, yet its a lighter flashlight. That is quite impressive! (someone correct me if Im wrong).
Stock, id personally take a TN32, but they are both very impressive in their own way.
I have ordered TK61 though..
