Anyone have one of these $1.99 lights?
These don’t look like the cheap Police lights. If they are any good they might be great to gift.
http://www.ebay.com/itm/Promotions-Bright-3W-LED-Mini-Pen-Style-Torch-Flashlight-1x-AAA-Battery-w-Clip-/301220824942?pt=LH_DefaultDomain_0&hash=item462229076e
Here is another.
http://www.ebay.com/itm/5-Pcs-3w-AAA-1Mode-Mini-Pen-type-Led-Flashlight-Torch-Lamp-MXDL-Red-/380679794063?pt=LH_DefaultDomain_0&hash=item58a248ad8f
I have found the Hugsby 1-AAA a great little light to gift. However, these are much cheaper.
Jerry
I know the MDXL and I’m not impressed. Both of these lights have all the typical characteristics the police lights are known for:
- pressed-in plastic lens
- cheap bluish LED, very dim
- simple one mode boost driver
- thin body with low quality (e.g. the threads)
    At least the driver/LED of the MDXL can be pulled out from the back of the head, most of these lights have press-fitted lenses wich holds the reflector and the “pill” (a cheap plastic part). If you try to push it out from behind, the reflector may crack and the pill will be destroyed (my experience). You get only what you’ve paid for.
Thanks, and that settles that. I thought the price was too good to be true.
Jerry
When you say police lights, are these the type of flashlights the police use in the states? Or was that a brand name?
It’s not really either of those. The term “Police light” is somewhat of a misnomer. It is not a brand, as there are several brands and non-brands that make “Police lights”. Our Police force are smarter than to use these cheap lights, so it isn’t that either. Perhaps it is clever marketing, because some people will believe that they must be quality lights if they say “Police” on them. Or, just maybe, in the past, there was a quality product that was called a “Police light” and all these others have copied (cheaply) that one that probably doesn’t exist anymore.
Small Sun style IIRC... I had one of these:
http://www.dx.com/p/small-sun-zy-720-50lm-6000k-led-white-light-1-mode-mini-flashlight-silver-2-x-aaa-258533
Not worth much. It's okay for a throwaway maybe...
They have the reflector and lens both press-fit from the front, like Antenne says. The MXDL lights are much better. On the MXDL AAA models, the lens is plastic and press-fit in the front, but the reflector/emitter/"pill" press in from the back. If you want to spend some time with plumbing parts, a 12mm PCB and small driver can be used to modify it into a fun little 10440 light. I have one of these modded out with an XP-G2 emitter and a brass pipe cap for a pill:
https://www.fasttech.com/products/0/10002074/1148801-mxdl-xt-7119-3w-80-lumen-white-led-flashlight
It makes a surprisingly bright little light. The clip is pretty bad on this light, but the rest is surprisingly good. The factory pill is a plastic disposable piece that houses the low power driver and the 5mm emitter.
...also here in a 2xAAA size:
https://www.fasttech.com/products/0/10000618/1057212-mxdl-xt7224-3w-50-lumen-led-flashlight-with-clip
Very strange. I know I am new, but this is the first I have heard of ‘police lights’ and If I google them I end up with the red and blue flashing lights for your car (yep your can buy them, just illegal to use. In the years gone by my mum told me a story, my uncle had a cortina that he modified, and put a police siren on it. There was an event going on with crowds in the street, so he turned his siren on, and the crowds moved out of the way for them thinking they was police. I think they would of got into a bit of trouble if he got caught though lol).
There are a lot of budget flashlights that have the word "Police" printed on them even though they are all typically low quality units:
