The behavior described in the last paragraph is how my one working D4 works. I actually prefer this, as if I want to do a quick battery change my last mode is still remembered. If I want to “reset” it, a click of the e-switch will accomplish that.
So, I programmed a test board and my 2nd D4 with the text used in post 5 except with the 2018-01-24.hex file. Now I can not communicate with either one using my setup, even though I can verify continuity from the IC pin through the programming clip to the USBASP. One poster suggested this is a confirmation that the MCU is “bricked”.
Is there any other test I can run before I go through the process of swapping driver boards (if I can find one available) or swapping out the ATTiny85 (I do have the capability to do this)?
